The master bedroom suite includes a large sitting area not seperated from the sleeping area by a door. Is Arc Fault protection required (house built in 2005) in the sitting area?
That would be part of the bedroom. You would have to check what your
jurisdiction follows codewise, and when it was implemented, if that interests you. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
If closets are considered part of the bedroom, this room would be also provided there is no other means of egress into the room.
Thanks guys. I thought it was required but couldn't find specific code language.
AFCI - From the 2002 NEC. (ALL outlets - bold is mine)
- 210.12 Arc-Fault Circuit-Interrupter Protection. - - (B) Dwelling Unit Bedrooms. All branch circuits that supply 125-volt, single-phase, 15- and 20-ampere outlets installed in dwelling unit bedrooms shall be protected by an arc-fault circuit interrupter listed to provide protection of the entire branch circuit. From the 1999 NEC. (ONLY "receptacle" outlets - bold is mine) - 210-12. Arc-Fault Circuit-Interrupter Protection - - (b) Dwelling Unit Bedrooms. All branch circuits that supply 125-volt, single-phase, 15- and 20-ampere receptacle outlets installed in dwelling unit bedrooms shall be protected by an arc-fault circuit interrupter(s). This requirement shall become effective January 1, 2002. Fittings; and Handhole Enclosures |
Yes, it is required to be AFCI protected for the outlets ( 15 & 20A. 125V ) within that bedroom.
Paul W. Abernathy |
| AFCI's Explained by Mike Holt & Eaton Engineer | pabernathy | Electrical Inspections | 19 | 2/15/07 12:05 PM |
| Houses with AFCI Breakers.... Basic testers shut off AFCI breakers?!? | jwatts1 | Electrical Inspections | 22 | 12/20/06 7:39 PM |
| Can an AFCI offer GFCI protection | gbeaumont | Electrical Inspections | 19 | 7/6/06 11:45 PM |
| Phoenix area Chapter Meeting - Jan 24th | cvowell | General Inspection Discussion | 0 | 1/11/06 5:00 PM |
