Kip McCullough is a non-member guest and is in no way affiliated with InterNACHI or its members.
I understand that AFCI are required at bedroom recepticles for new construction, but are they required for overhead lights and ceiling fans in bedrooms? If I'm correct, the 2002 NEC only requires AFCI at bedroom recepticles on new construction.
Thanks, Kip McCullough KRM Home Inspections, LLC Atlanta, GA |
All 125 volt, 15 and 20 amp, single phase outlets.
An "outlet" is any point of power supply (basically) which includes smoke detectors, lights, receptacles, etc., etc. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jon Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
In most areas of ME, smoke detectors are exempt from the AFCI requirement.
That would have to be a local AHJ thing Jon, because based on the NEC as a whole it requires them to be on the AFCI circuit. Many fight the idea that if the AFCI circuit goes off the smoke circuit will also.....Yet I would argue that the advantage of this is the notice you would get from the AFCI system via the smokes....since as we know the smokes are required to be of battery back up nature......anyway....not a all together bad thing when on an AFCI circuit......
Usually we feed a bedroom...smaller one of the closest nature...let it feed the smoke circuit and then loop it so they all are covered by AFCI....very important to note that AFCI can leave the bedroom and pick up other items....and you can have more than (1) AFCI within a bedroom....just wanted to throw that in for ya. Paul W. Abernathy |
I caution folks from calling out missing AFCIs on new construction. You need to ask the AHJ if they require it, because not all do. AFCIs are not required on new construction in NY State... period.
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Joe, Below is info I lifted off of the "New York State Division of Code Enforcement and Administration". Is your info something new? Are arc-fault circuit-interrupters required in residential buildings regulated by the BCNYS? YES. Chapter 27 of the BCNYS references the 1999 version of the NEC which in section 210-12, requires arc-fault
circuit-interrupter protection for all branch circuits that supply 125-volt, single-phase, 15- and 20- ampere receptacle outlets installed in dwelling unit bedrooms (effective January 1, 2002). |
Russel,
Is that a link from your IRS? - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Yes.
We've only recently been noting absence (or presence) of AFCI breakers, so I had to come up with something to explain why my Clients should have AFCI breakers installed, and something to explain what they do if they were installed. Ultimately all of my IRS reference materials will be at About Homes, but the PowerPoint presentation (think marketing) won't be there, just the information. About Homes and the materials there are free to NACHI members through March 31, 2006, so check often (I create and/or upload information daily) and make sure you join us as a home inspector at our discounted NACHI rate prior to March 31, 2006. |
I agree....I think your question is very important Jeff.....because even back to 1999 the AFCI was mandated for 2002 as I believe Charles posted as well. The local AHJ certainly has the ability to modify the NEC but I am not in NY so I dont know but from all the places I deal with AFCI's are now required....yes I can see some saying the smoke is not on the circuit but from an electricians standpoint it is moot...their is no way in getting around the wording of the NEC on the issue of AFCI's in bedrooms....the smoke is 120V and should be on AFCI....period.
Paul W. Abernathy |
However, the 2000 IRC as a "stand-alone" code does not require any AFCI protection for bedrooms (see IRC E3802). That was added to the IRC in 2002 (E3802.11) Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
And just for clarification, note that most, if not all, of the jurisdictions here are still using the UBC from ca. 1996, which, I believe, didn't even know that AFCI's existed. Yet I as a home inspector here regularly recommend the upgrade.
Just to be clear......I as an electrician wire to the NEC and it is refered from the UBC here in VA....and probably in most cases. In other words they are going to refer to the standards of the NEC if adopted in the state.....and the NEC is clear on the AFCI requirements I believe....
Now if the local AHJ chooses to waive certain portions of things it is within their Art 90 power to do so. RR....Does the UBC not refer you to the NEC on electrical installations and requirements...and if so what NEC edition has been adopted in your state? Paul W. Abernathy |
The current RCNYS is based on the 2000 IRC, which does not require any AFCI protection (see E3802) ... unless you also apply the 1999 NEC, which some AHJ's may do (I think incorrectly, since E3802 does not kick you out to the NEC). Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 2/10/06 at 12:11 PM.. |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
