Old 12/2/07, 11:52 PM
Christopher Currins's Avatar
Default AFCI Breaker/GFCI Rec
Can an AFCI breaker take the place of a GFCI Rec. in a wet location?
Christopher Currins
Certified, Licensed
Old 12/2/07, 11:58 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: AFCI Breaker/GFCI Rec
Christopher
AFCI devices have a Class "B" type of GFP protection. This is generally set at 20-40 miliamps.
Where a GFCi device is a Class "A" type device, which is set at between 4 and 6 Miliamps. This is the type required for most GFCI applications.
Old 12/3/07, 12:50 AM
Originally Posted by Pierre Belarge
Christopher
Thanks, do you see a GFI breaker in this panel On the ledger it states two bathrooms (which have normal rec.) are covered by GFI breakers. All I see are the AFCI. Also All 20 amp breakers.
Christopher Currins
Certified, Licensed
Old 12/3/07, 12:55 AM
Stephen W. Stanczyk's Avatar
The breaker with the red test button is the GFCI.
Stephen Stanczyk
Old 12/3/07, 2:04 AM
That is the only one I found too. It states that breakers 16 and 18, on the right are protecting the bathrooms with GFI protection. It was built in 2003, I thought maybe i was missing something.
Christopher Currins
Certified, Licensed
Old 12/3/07, 2:14 PM
Found my answer..
http://www.eaton.com/EatonCom/Market...iteId=EatonCom.
Christopher Currins
Certified, Licensed
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
AFCI Controversy rcooke Electrical Inspections 11 9/10/07 2:14 PM
AFCI's Explained by Mike Holt & Eaton Engineer pabernathy Electrical Inspections 19 2/15/07 12:05 PM
