Should we be recommending to our Clients to Upgrade their Bedroom circuit breakers to AFCI's if their house was built before the code was
required? David |
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
How do you report GFCI's? Why would you not handle AFCI's the same way? Why just bedroom circuits?
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Same answer for any health or safety upgrade. If they ever upgrade their Electrical system Circuit Interrupters should be installed according to present code. I also recommend GFCI for all outlets at wet locations so why would I not recommend AFCI protection. It is present code because it is better for your safety. |
Remember that a building code, when adopted, is nothing more than the most minimum and basic level of acceptability to the degree that anything less is illegal. A building code does not indicate that something is "safe" or that something is of any degree of quality. AHJs are limited and can only observe and address these minimum basic standards. Home inspectors, however, are not looking at the least amount of quality or materials to get by....but what is good and right, and what is not. Never ever discuss your findings in terms of "code" or you will be made to look like an idiot by contractors and AHJs who freely misinterpret them for a living. Allow them to reign over their mediocrity while you address material defects and the means of improving the quality and safety of the home and its systems. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Interesting. How many of you recommend installing fire-suppression systems in the residence as a "safety upgrade?"
Not me...but my state SOP does require me to report lack of GFCI's & AFCI's.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Great question. For those who insist that aluminum wiring and two-prong electrical systems (all acceptable under the NEC) should be written up as "defects" in an inspection report...how do you justify NOT writing up the actual 2006 IRC requirement for fire-suppression systems in two or less family dwellings? This should be fun. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
By not adopting the 2009 amendments, Minnesota will not be requiring home sprinklers for at least five years, if ever.
Effective Date:
The IRC provision calls for an effective date of no sooner than January 1, 2011. If the state adopts the IRC by January 1 the provision will apply. If adoption occurs after January 1, 2011 then only those homes built after adoption will be required to comply. There is no retroactive provision in the code. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
At the last legislative session, at the behest of the builder's lobby, Texas passed a law prohibiting the requirement of residential sprinklers. They can be offered but not required here:
I'm looking to get a feel for the "logic" behind recommending such an "upgrade." I've pondered this question for some time now and, with the help of my legal counsel, have learned where I should "draw the line." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
How is it a different story? The question is "Should we be recommending to our Clients to Upgrade their Bedroom circuit breakers to AFCI's if their house was built before the code was required?"
It doesn't seem wise for me to simply state "AFCI not present". I do expand upon the subject some to explain what an AFCI is and why I recommend considering them if they are not present. I think it all goes back to the age-old question of whether or not to report pretty much anything that is missing or deficient in the home doesn't it? Another similar example would be 8" gaps at stair balusters, would you mention that? I do agree that we all have to draw the line somewhere but that line will vary from state to state and inspector to inspector. |
I'd like to hear from more inspectors before I tell you where I draw my line. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
There is no doubt that the AFCI will save lives and prevent $$$$$ in fire damage. The reason to recommend upgrades is that an older home will be significantly safer with the upgrade at a reasonable price.
My list of recommended upgrades are: smoke detectors, railings, railing balusters, GFCI's, sensors at garage door openers and hurricane ties. I will be adding AFCIs in the near future. www.MauiHomeInspectors.com |
| AFCI question | mroach | Electrical Inspections | 9 | 10/17/09 6:16 PM |
| Half Height Breaker Question | bsmith | Electrical Inspections | 2 | 9/10/09 7:54 PM |
| Vacuum breaker Question, Pic included | dnasser | Plumbing Inspections | 2 | 1/6/09 12:03 AM |
| Breaker Question | rsole | Electrical Inspections | 6 | 11/23/08 10:57 PM |
| AFCI question | mtimpani | Electrical Inspections | 7 | 3/17/08 9:01 PM |
