Please help.....New construction AFCI breakers finding them warm to touch. Temp. tested at 100 degrees. Is this normal?
Called several electricans and got mixed bag of answers.... Help? |
Yes, that's completely normal. The manufacturers say that they may have up to a 40 degree temperature rise over ambient. Sorta throws you for a loop, doesn't it?
For this reason, some installers prefer to leave a blank space or a regular breaker between groups of AFCI breakers. Keeps them from heating each other up so much. Give a little room in between to cool off. This isn't expressly required by any manufacturer, but some installers consider it good practice. |
Yep. They actually have computer circuitry in them that run a little hotter than normal. The circuitry looks at the wave form and checks it against the wave form of an arc.
Normal. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I would note if they are stacked more than three together as I remember at least one AFCB manufacturer recommended this be the max...
No real concerted agreement on this either though... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Even the GFCI runs into the 90's with nothing on the circuit.
Low voltage transformers are another one (up to 120). |
I understood it most AFCI's are rated 140 degrees F. As do not all breakers need to have the temp ratings on them?
Anything around or over this temp. I state futher evaluation by a licensed electrician. Ray |
So how much power does that represent? Maybe 10 watts each AFCI (a total SWAG)? Times maybe 10-15 breakers per panel after the new code edition. Times several hunderd thousand new panels per year... Do you suppose these costs were considered by the code generators at NFPA?
lol....well I spoke with Eaton on this and they have done tests....stacking does not harm anything as they have a good allowance of heat factored in.
IN regards to spacing....the new 2008 NEC will make that moot..since all 125V 15 & 20A circuits will require AFCI so people higher than US have determined it is not a problem...... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
There are over 32 pages of comments on AFCIs in the ROC. NFPA is still pressing ahead on the universal requirement.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| AFCI Controversy | rcooke | Electrical Inspections | 11 | 9/10/07 3:14 PM |
| Stacking AFCI, GFCI breakers | abolt | Electrical Inspections | 6 | 4/17/07 11:57 AM |
| Houses with AFCI Breakers.... Basic testers shut off AFCI breakers?!? | jwatts1 | Electrical Inspections | 22 | 12/20/06 8:39 PM |
