Old 3/3/09, 7:42 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default AFCI not a GFCI on jetted tub
ok????
or should it be a GFCI breaker?
No other protection installed, this breaker stopped the jets...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 3/3/09, 7:48 PM
Bruce A. King's Avatar
Default Re: AFCI not a GFCI on jetted tub
Should have a GFCI somewhere, were you able to check under the tub or in the crawlspace for one? Sometimes they hide an outlet above the floor insulation in the crawl.
Also, don't think you can have both AF and GF on the same circuit.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/3/09, 7:50 PM
Originally Posted by bking View Post
Should have a GFCI somewhere...
Agreed...
Larry Kage, CMI
231 929 3525
Old 3/3/09, 7:52 PM
Completely tiled in surround. No GFCI only type on any wall surface of the bathroom, fully elevated drywalled beneath the sub floors. And it functioned to disconnect the tub jets.
I'm thinking they should have used a GFCI (req'd) but used an AFCI breaker instead.
- Mike
NACHI05040682
(843) 442-9755
Old 3/3/09, 7:53 PM
Originally Posted by lkage View Post
Agreed...
But doesn't, and I think they thought this was "protection too"
- Mike
NACHI05040682
(843) 442-9755
Old 3/3/09, 8:41 PM
Bob Elliott's Avatar
Those are plugged in and there should be an access panel.
Fault may lie with the decorator,not the Electrician.
Must admit I never saw a circuit with both though.
Old 3/3/09, 10:23 PM
Jeffrey R. Pope's Avatar
There's no reason you can't have both, but GFCI protection is required - regardless.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/3/09, 10:28 PM
Michael R. Boyett's Avatar
Michael, did the bath have a separate toilet room? Electricians are known to place hydro-therapy tub GFCI's there if there is no easy under tub access, at least around here they do.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 3/3/09, 10:45 PM
Brian E. Kelly's Avatar
Same here, or sometimes in the master closet. And always behind a bathrobe or something else.
Old 3/3/09, 11:14 PM
Joe Funderburk, CMI's Avatar
Sometimes you just can't confirm a GFCI. Then, I say this:
"We could not confirm that the hydro-spa is equipped with ground fault protection, which is an important safety feature that should be verified as being present or added. Ground fault circuit interrupter (GFCI) receptacles have been required for spa tubs since 1987."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/3/09, 11:33 PM
Just fill with water and throw in a toaster.
See if it trips.
Old 3/7/09, 10:02 AM
See if it trips.
OUCH....glad I did not say that...lol
Paul W. Abernathy
Old 5/1/09, 7:50 PM
Interesting thread. I just found a AFCI on a jacuzzi tup circuit today on my afternoon inspection. I could not locate a GFCI breaker anywhere.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared Thermographer®, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 5/1/09, 8:14 PM
I've seen them use AFCI's on exterior outlets. Old school electricians I guess..."if it's newer, it's better".
Theodore Roosevelt
Joe Funderburk, CMI
Old 5/1/09, 8:21 PM
Stephen W. Stanczyk's Avatar
I always find them in the master closet BUT in a couple instances with the large tile surround tubs, there is a single tile at the motor end that is held in place by strong magnets. The installer will supply a special suction handle to remove the tile with. You have to look real close at the space between the tiles. If there is no grout or you can see the seam, it is in back of the tile.
Stephen Stanczyk
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Afci & gfci rfitzwater Texas/TPREIA Inspectors 12 2/27/09 8:30 AM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
Stacking AFCI, GFCI breakers abolt Electrical Inspections 6 4/17/07 10:57 AM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/6/06 11:45 PM
