I looked over the message board and AFCI usage states: 15 and 20 branch circuts for outlets. Are AFCI breakers also mandatory for cieling fans?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Picture aid...
We have a county here in SC (Lancaster county) that does not allow bedroom smoke detectors on AFCI circuits. Another one (Richland county) does not require AFCI's at all.
Of course, this could all change tomorrow.... which is why we are not required to keep up with the whims of AHJ's. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Very nice pic, and great info Marc!! Thanks!
Never thought of the difference between the two words before.
I will remember that, |
The graphic shows "switch outlet", which is technically incorrect in many cases. A switch is only an outlet if it's a lighted switch or a timer switch or similar type of switch that actually uses electricity. A regular snap switch is not an outlet, and is not required to be AFCI protected. That said, if that switch is controlling a load within the bedroom, it probably will be AFCI protected anyhow. Switches in the bedroom that control items outside the bedroom, such as an exterior light on a master bedroom deck for instance, are not required to be AFCI protected unless that switch actually consumes electric by some means. As the 2008 gets adopted more and more, it will be a moot point, since most of the home will have an AFCI protection requirement.
I hope someone at NACHI is preparing some educational material regarding the 2008 AFCI requirements, since I know many of you do draw inspections and new home inspections. These new requirements can be a little confusing, with regard to which areas require AFCI protection and which don't. Just a head's up to whoever controls the educational end of things. |
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Up here in the great white north, they are only required on bedroom receptacles.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/13/10 12:51 AM |
| Hypothetical AFCI question... | mgault | Electrical Inspections | 11 | 7/12/07 7:08 PM |
| AFCI question | jjordan | Electrical Inspections | 6 | 8/22/06 3:30 PM |
| AFCI question | cbuell | Electrical Inspections | 23 | 8/9/06 12:31 PM |
