Old 10/15/09, 7:39 PM
mroach's Avatar
mroach mroach is offline
Please Note: mroach is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default AFCI question
I have come across 2 new homes that had the outlet for the gas oven on an AFCI circuit. I would think that this would not be a outlet that you would want on a protected circuit. It only powers the controls for the oven. i would think it would be a nuisance to have it trip while you are cooking something and not realize it. Just like I wouldn't want it on a GFCI circuit.
I have searched the codes and can not find anywhere stating it is not allowed. Any thoughts?
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 10/15/09, 7:58 PM
Jeffrey R. Pope's Avatar
Default Re: AFCI question
They are required in specific locations, but are not prohibited in any location.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/15/09, 8:11 PM
Brian E. Kelly's Avatar
Less is more, great answer Jeff.
Old 10/15/09, 11:57 PM
Chuck Evans's Avatar
I see no issue, but i think it's interesting that the arc from the igniters doesn't trip them.
Perhaps Paul or Gerry can explain why???
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 10/16/09, 12:45 AM
Michael R. Boyett's Avatar
The arc or 'spark' that you see at the burner is not directly from the 220 vac or even 110 vac. It is generated by an electronic module that essentially buffers the spark from the power line.
Old 10/16/09, 12:53 AM
Attachment 32641
Another good answer. Simple and to the point. Excellent.
Old 10/16/09, 1:06 AM
Bruce A. King's Avatar
Since many people will get AFCI and GFCI mixed up, I thought it would be a good idea to post this on this thread too.
Quote below is from the manual, page 11, found at http://www.electroluxusa.com/files/u...install_en.pdf
"Do not plug the cooktop into Ground Fault Circuit Interrupter (GFCI) receptacles.
The cooktop spark ignition module can cause a GFCI to trip."
www.BAKingHomeInspections.com
704 301-3207
Old 10/16/09, 1:20 AM
Attachment 32641
Thanks, That makes sense they would use capacitors and step the voltage up quite a bit in order to get the arc to jump the gap.
Houston, TX
Old 10/17/09, 4:33 AM
Paul W. Abernathy's Avatar
The non-typical parallel or series "ARC" that an AFCI is looking for is measured based on the last half cycles of the "ARC" itself so this is why motors that have a arc while starting or a switch that arcs does not set off an AFCI. It can determine what a good arc is from a bad arc if you will.......they are way more precise and should not be affected by those types of non-dangerous types of arcs.
Paul W. Abernathy,CMI,CPI,CME
Old 10/17/09, 6:16 PM
Thanks for the additional info. It's always helpful
Houston, TX
QOD for 1/26/07 - AFCI's jbowman Inspection Question of the Day 43 7/28/09 3:18 PM
AFCI question mtimpani Electrical Inspections 7 3/17/08 9:01 PM
Hypothetical AFCI question... mgault Electrical Inspections 11 7/12/07 7:08 PM
AFCI question kweiss Electrical Inspections 19 11/4/06 6:03 PM
AFCI at bedrooms on new construction? Kip McCullough Electrical Inspections 41 2/12/06 8:58 PM
