Old 10/4/09, 10:53 AM
Joe Funderburk, CMI's Avatar
Question AFCIs...a solution to aluminum wiring?
Would AFCIs be a good solution to a house wired with aluminum wiring? I understand re-wiring is best. But how would an AFCI work as compared to copalum crimping?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America)
Old 10/4/09, 11:47 AM
Bruce A. King's Avatar
Default Re: AFCIs...a solution to aluminum wiring?
It would not be a total solution since a bad aluminum connection under load can slowly heat up to the point of ignition. AFCI's are programmed to detect only the most common arc waveforms. Having them installed as another level of safety is a very good idea. Aluminum wiring was one of the original reasons they developed AFCI's.
Be careful in implying that AFCI's are easy to install, it is common to have shared neutrals and problems that will trip the AFCI as soon as its turned on. The labor involved to correct the wiring can be enormous.
www.BAKingHomeInspections.com
704 301-3207
Old 10/4/09, 11:59 AM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think AFCI's might also be a good idea with knob & tube wiring. I have even recommended it as an 'upgrade' a time or two for homes with K&T.
Now where can I get a AFCI screw in fuse?????
Old 10/4/09, 12:03 PM
Jeffrey R. Pope's Avatar
Rewiring is not the best solution. Unless you feel that buying a new car is the best solution for flat tires.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/4/09, 12:08 PM
Jeff, what is the best, most practical, solution?
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/4/09, 5:29 PM
The point of attachment is where the problems lie with AL wiring. Correcting the connections is far less expensive than rewiring a residence.
Copalum crimps are a reasonable solution. There are new products available as well, but I don't have that info handy.
Installing AFCI's could be helpful if the residence is wired in a manner that will accept the breakers currently available.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Aluminum Wiring jhagarty Electrical Inspections 23 10/5/07 3:56 AM
Aluminum Wiring acox Electrical Inspections 4 8/27/07 12:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 4 3/25/07 11:41 PM
