Old 4/30/11, 7:57 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default All 20 amp breakers
1995 house electrical panel wired all with 12 ga. and 20 amp breakers, no 15 amp breakers for lighting, etc. Are lighting circuits supposed to be 15 amp?
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/30/11, 8:10 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: All 20 amp breakers
No, there is no requirement to use any 15 amp branch circuits. In some jurisdictions #14 AWG branch circuits are prohibited with #12 AWG conductors being the minimum size.
Old 4/30/11, 10:07 AM
David A. Andersen's Avatar
It would be nice if they did this more often, less voltage drop issues to deal with.
BPI# 5015804
Old 4/30/11, 7:21 PM
agallatin agallatin is offline
The Sparkys here don't like this . It would mean work would be harder making their connections . I asked for that in my shop for all my plugs . But man there was a lot of gripping about it .
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 4/30/11, 9:42 PM
John E. Mullarkey John E. Mullarkey is offline
Dave is right, run #14AWG over 50' and you start to have problems with voltage drop. With all the sensitive consumer electronics about it is starting to become a problem.
Old 5/1/11, 10:48 PM
Marc D. Shunk's Avatar
Banned
A man would be hard pressed to make an argument that voltage drop causes any problems in a residential setting. The tool that home inspectors use to measure this has a HUGE flaw.
Carry on....
Old 5/1/11, 11:03 PM
Banned
Carry on....
Hello again, Mark......welcome back.....maybe only for a while though!~!~! LOL!!
When I wired under a licensed gent in the 1970's, it was required that feeds over 50 feet in houses be #12......somewhere along the line this requirement was dropped......the V drops were insignificant
Old 5/1/11, 11:05 PM
Banned
I understand, but I think you are parroting old wive's tales. That requirement does not appear in NEC that has ever existed.
Old 5/2/11, 7:58 AM
I think when we find 93 VAC at a wall outlet without a significant load, there may be an issue involved.
When you don't have the supplied voltage required by the equipment Mfg, this is not an issue?
Also, when I find a voltage drop with one of thoes nifty testers and then find overheated wiring inside the finished wall with Thermal Imaging is of no concern?
Yes, there is a lot of wive's tales around here Mark. However disclaiming the issue with a blanket statement may not be best.
BPI# 5015804
Old 5/2/11, 8:02 AM
I think that Marc was saying that the NEC has never required voltage drop compensation. He just has a special way of saying it.
Old 5/2/11, 8:45 AM
Banned
I'm in Canada!!
Old 5/2/11, 8:50 AM
I'm in Canada!!
So VD compensation is required in Canada?
Old 5/2/11, 8:53 AM
Jim Port Jim Port is offline
Unmoderated Guest
Does this require a shot? . Who pays, the giver, the receiver?
Old 5/2/11, 9:21 AM
Banned
How much would that be??? LOL
It was but not now in residences....I never worked commercial, etc.
Old 5/2/11, 6:45 PM
Terry Clayton Terry Clayton is offline
Talking Re: All 20 amp breakers
Hello David A. Andersen, I am not picking on you just asking if you have any IR pictures depicting the elevated IR signature of the wiring concealed with in the wall. I understand if there is a load applied to the circuit you may see a elevated temp due to the equipment drawing additional current because of the reduced voltage. The comments you posted just may not have given all of the info I needed to understand it. Thanks I am just trying to learn.
Siemens recalls circuit breakers due to fire hazard. gromicko Electrical Inspections 3 9/24/10 7:36 AM
Main panel...recommendation ? dnasser Electrical Inspections 6 11/22/09 9:55 PM
