Hi guys, I'm doing report now on house today that had a solid alum #8 wire for 30amp breaker for a dryer outlet. Is there something special about dryer outlets that makes this ok? I'm calling it out but will check back in a little bit before I finish to see what every one says. thanks, Mark T
Every thing else was copper and correct except for that. |
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
Well views will vary on this....the 8 AWG AL is rated for 40A depending on the rating of the terminals at both the breaker and the dryer receptacle. If the rating is not shown then you would use 60 degree column @ 310.16 of the NEC which would give us still 30A.
So ask yourself these questions....... 1.) What is the rating of the terminals at both the breaker/fuse and at the dryer receptacle? 2.) Are the terminals at both ends rated for AL Wiring? 3.) Is the 8 AWG in a conduit? ( Hope Not ) Remember 8 AWG is I believe the last acceptable solid conductor before we venture into stranded conductors....except of course 6 AWG solid used for GEC's and so on...but I digress. Again nothing illegal about it in the eyes of the NEC, the real issue is with the terminals and knowing their ratings. If you are calling other items about for an electrical contractor to look at you could without remorse call for them to be torqued properly or check for reliable connection while the electricial contractor is their.....but if that was the only issueI would not have that be a flaring issue. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Thanks Paul
| Top Ten Wiring Hazards Threaten Life and Property | jtedesco1 | Electrical Inspections | 3 | 9/2/08 6:15 PM |
| Top Ten Wiring Hazards | jtedesco1 | Electrical Inspections | 6 | 9/1/08 9:26 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| K&T splice. | egarcia1 | Electrical Inspections | 13 | 2/3/07 7:36 AM |
