Anyone seen these new copper/aluminum connectors out there? Know anything about them? I have a friend who is doing some re-modeling in his home and he wants to make sure his connections are safe. He is asking me about them, but I've not seen them before.
http://www.alcopstore.com/ Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
There have been several discussions here about these. It is probably as good a solution as there is if you have the room in the box for them. They are as good as the heavily hyped Copalum
I agree with Greg. These are a good alternative to the Copalum crimps, and don't require any special training or "certifications."
The only down-sides (if you will) is that these aren't an "irreversible" connection and they require that the installer provide proper torque, which requires the proper tool. Homeowners or other unqualified personnel may be inclined to disregard the torque requirements rather than purchase a torque-driver. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I got a baggie of these for free from a salesman, but I keep forgetting that I have them. I'll have to give them a whirl one day. They are bigger than they look on an internet picture, so they'll fill the box up pretty quick. As with any aluminium termination, the use of a torque screwdriver is an absolute must. Furthermore, if an electrical contractor is installing these, his torque screwdriver had best have recent verifiable calibration as a simple CYA move. The calibration date of the torque screwdriver should be recorded on the invoice and any other paperwork associated with the aluminium job.
There is an alternative approved torquing method. Which doesn't require a torque wrench.
Just follow the directions. tom P.S. The only way to make solid branch wire 100% safe is to remove it, so there is a risk associated with everything. Including crossing a street or eating, or even sleeping. |
http://www.kinginnovation.com/pdfs/5...-AlumiConn.pdf |
tom |
The listing is given based on use of the proper tool. That sentence pretty much says it all - it's not a listed connector unless it has been properly torqued.
You could use a radiator hose clamp to hook a ground wire to a pipe and it might do a fine job, but the UL never evaluated radiator hose clamps for grounding use. This is just a parallel example. |
Question: Are CO/ALR devices avaiable, or are they hard too find?
Lowes |
| Gas appliance connector | mboyett | Inspecting HVAC Systems | 14 | 12/27/07 7:51 AM |
| Gas flex connector to furnace | jcahill | Inspecting HVAC Systems | 25 | 7/24/07 6:22 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
| Help Identifying connector | Steven Brewster | Electrical Inspections | 5 | 4/10/06 11:00 PM |
