Old 5/11/06, 1:02 PM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
Default Aluminum or tin coated copper wire??
Inspected a home yesterday, built in 1942, that at first glance appeared to have some single strand aluminum wire in some areas feeding out of an old fuse sub panel. (The main panel has been recently upgraded to a 200 amp service). Then I noticed that at some connections where the outer coating had been scraped, it looked like copper color underneath.
Could this be aluminum coated copper, tin coated or silver coated copper?
It doesn't look like any of the wire at this site. http://www.inspect-ny.com/aluminum/ALid16.jpg.
The wire appears to be original to the 1942 house. The covering is not plastic, it's that older style, kinda cloth type insulation. My pictures probably don't show it very well.
Can anyone help me with what this is? Is it a concern?
aluminum-tin-coated-copper-wire-p1010003.jpg   aluminum-tin-coated-copper-wire-p1010004.jpg   aluminum-tin-coated-copper-wire-p1010001.jpg
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 5/11/06, 1:28 PM
Default Re: Aluminum or tin coated copper wire??
I have never seen or heard of any aluninum 12 or 10 that was anything but TW insulated in a plastic jacket. You are looking at tinned copper.
Old 5/11/06, 3:04 PM
That was the conclusion that I was coming to, also. Thanks Greg.
Mark
MD HI Lic # 30090
Old 5/11/06, 5:12 PM
Roy D. Cooke, Sr's Avatar
This is back in Knob and Tube . It is tinned copper and the reason why the wire was tinned is because all joints where soldered back then an tinned wire was a lot easier to solder . The wire was rubber coated and cloth covered . Move it now and the insulation easily falls off.
Been there done that .
Roy sr
Old 5/12/06, 9:29 AM
Thanks, Roy.
Mark
MD HI Lic # 30090
Old 5/14/06, 10:39 AM
Guy White Guy White is offline
Alluminum Wire came into common use in the seventies.
Old 5/14/06, 1:30 PM
StanAccy StanAccy is offline
Please Note: StanAccy is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are there any issues using wire nuts to connect the old cable like this to new copper cable in Romex?
On a related note, how easy (or difficult) would it be for an electrician to pull out this old cloth coated wire, and feed in new conductors?
Old 5/14/06, 3:30 PM
Tinned copper is still treated like coppere. You don't have the aluminum issues
Old 5/14/06, 11:36 PM
jmichalski's Avatar
jmichalski jmichalski is offline
Please Note: jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not entirely accurate.
From this site (http://www.inspect-ny.com/aluminum/aluminum.htm#alhaz):
"Aluminum wiring, used in some homes from the mid 1960's to the early 1970's, is a potential fire hazard. How safe is aluminum wiring? According to the U.S. Consumer Product Safety Commission, fires and even deaths have been reported to have been caused by this hazard. Problems due to expansion, or more likely micro-fretting and arcing at the connectors, can cause overheating at connections between the wire and devices (switches and outlets) or at splices. The connections can become hot enough to start a fire without ever tripping a circuit breaker!
CPSC research shows that "homes wired with aluminum wire manufactured before 1972 are 55 times more likely to have one or more connections reach "Fire Hazard Conditions" than are homes wired with copper. "Post 1972" aluminum wire is also a concern. Introduction of the aluminum wire "alloys" in 1972 time frame did not solve most of the connection failure problems. Aluminum wiring is still permitted and used for certain applications, including residential service entrance wiring and single-purpose higher amperage circuits such as 240V air conditioning or electric range circuits. The fire risk from single purpose circuits is much less than for branch circuits. But it's not necessarily because of a "new alloy" as some folks assert. It's because there are enormously fewer connections (four or six rather than 30 or 40 per circuit) and thus statistically a smaller chance of a connection failure. These connections do still burn up, as indicated by field reports."
It is a concern near that time frame, but aluminum wire concerns go back to the 60's...
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Tin coated copper question bking Electrical Inspections 13 6/19/07 12:50 PM
aluminum coated copper or straight aluminum? Scott Schultz Electrical Inspections 6 3/3/07 12:22 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 12:22 PM
