Old 1/16/08, 8:28 PM
Spencer B. Johns's Avatar
Spencer B. Johns Spencer B. Johns is offline
Default Aluminum wire
Can you have 2 neutral (aluminum wires ) under the same terminal in the main panel? I did an inspection today and this was the case. Older home, panel and wires looked fine.
Old 1/16/08, 8:34 PM
Jeffrey R. Pope's Avatar
Default Re: Aluminum wire
The AL conductor is a much greater concern. Doubled up makes it just that much worse.
I assume you're referring to solid AL?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/16/08, 8:40 PM
chunt1's Avatar
chunt1 chunt1 is offline
Please Note: chunt1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lots of information regarding aluminum wires here.
Neutral wires carry current and industry standards do not allow more than one wire per terminal on the neutral bar in a panelboard.
Read here for more information and a good graphic depicting the neutral wire installation:
http://www.nachi.org/forum/showthrea...apped+neutrals
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Here's the advertisement for aluminum wire first 58? jtedesco1 Electrical Inspections 18 1/6/07 2:10 PM
Aluminum or tin coated copper wire?? mlong Electrical Inspections 8 5/14/06 11:36 PM
