Just got this Email from a fellow inspector posted here with his permission
See updated PDF Hey Guys, Conducted an inspection yesterday on a 1960’s house in Dallas. Bank owned. Aluminum wiring. The whole nine yards. Anyway, thought I was going to have to call the fire department. During my sampling of outlets to check wire connections, had an outlet and wires arc and start a small fire in the box. See pictures attached. Anyway, what I’ve read about “pig tailing” as unreliable was demonstrated yesterday. Obviously turned power off to property and alerted selling agent immediately. Also, I’ve also attached a document with some updated information about aluminum wiring I thought you might be interested in. That’s it, stay safe! Regards, Brian Bassett, TREC #6581 Wall-2-Wall Home Inspections 817.721.4778 (cell) brianbassett@tx.rr.com www.wall2wallhomeinspections.com ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 9:21 PM.. |
Thanks Barry
Is it typical for TREC inspectors to "sample outlets to check wire connections"? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Hi Larry,
Yes TREC SOP states "Inspect (if branch circuit aluminum wiring is discovered in the main or subpanels) a random sampling of accessible receptacles and switches and report as in need of repair the absence of appropriate connections, such as copper/aluminum approved devices, pig-tailed connections or crimp connections". The buyer was very happy to have this information before purchasing this property. |
Thanks for the info. Nice job! InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
That looks more like a short than a loose connection. Did a wirenut pop off or a wire break and short to the box?
I see in that second picture that you found my 10-in-1. Thanks for keeping it safe for me.
Here is a link to the rules Texans work under... TREC Rules thanx JP also AlumiConn will send samples and flyers ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 1/24/08 at 7:13 AM.. |
I've run into this in the past. Ideal makes Al purple wire nuts. Some people see the cost and then next to them, are regular purple wire nuts. Another glance, they find no-oxide compound the shelf below, and the the light bulb goes on. Why pay $10 for four Ideal Al Purple Wire Nuts, when for $4 you can make a whole bunch of home-made ones!
tom |
Barry & Brian -
Good info! Permission to use photos please! -- bz Brian Zimbelman Circle Z Inspection Services http://www.circlezinspections.com 575-535-4481 (wk) 575-313-1281 (cell) |
Barry; I'm mot sure from your post if the pigtailing was or was not done with approved connectiors. If approved were they "COPALUM" or "ALUMICONN"?
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
This wasn't my inspection and the photo is too fuzzy to be certain, but as I James stated and from what I can see these appear to be the Ideal 65 "Twister" here's the AlumiConn in action, obviously due to their size/configuration excessive bending stress and box overfill is/may be an issue ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 9:21 PM.. |
Thank, I couldn't tell anything, but black and melty, from the photo. I have not seen the ideal twister in this area, I was hoping this wasn't "COPALUM" that I have seen.
Yes,
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
