| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yea... Multi-strand is no concern... It's the solid from the 70's that you need to write up.
That looks like tin plated copper conductors not aluminum. They used a tin coating between the copper and the rubber because copper reacted with the rubber insulation. The conductor should have a R in it's type. Likely RHW.
Thanks mark as always
I agree with Robert, tinned copper.
Thanks again everyone for the help
Tinned copper. . .
Oh you guys are to quick
nice handle-tie....
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Copper clad stranded. Even actual alum solid for other than branch circuts is ok. Used here all the time for water heaters, A/c units. Stranded alum. is used these days for main feeds also.
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
The copper wire clip used on the 15 amp and 2o amp seperate breakers Might be a concern though.
I would still agree with Jim and Jeffery, tinned copper. |
| Aluminum wire questions | jcahill | Electrical Inspections | 2 | 7/9/09 6:23 PM |
| Old wires. Copper or aluminum? | bforeman | Electrical Inspections | 6 | 10/19/08 7:35 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
