Old 6/1/06, 2:32 PM
Russel Ray's Avatar
Default Aluminum wiring
I've never seen single-strand aluminum wiring in circuits other than 15- and 20-Amp circuits. One of yesterday's inspections had the proper wire size in 40-amp and 50-amp circuits, but it was single-strand aluminum. Am I correct in my understanding that the larger aluminum wires do not have the same problems associated with them that the smaller wires do?
Old 6/1/06, 2:42 PM
gbeaumont's Avatar
Default Re: Aluminum wiring
Hi Russel, all single strand Aluminum should be concidered suspect, I would recommend that the circuits be checked by an electrician and that at least the connections are correctly torqued.
BTW what age was the home? as I have never seen Aluminum single strand in those sizes.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/1/06, 2:52 PM
Russel Ray's Avatar
Thanks, Gerry.
Home was built in 1978 with significant modifications in 1987.
Electric panel was I-T-E, vintage 1978.
Old 6/1/06, 5:58 PM
Jeffrey R. Pope's Avatar
I concur with Gerry. Only multi-strand AL should be considered "safe" for use as current carrying conductors.
When sized properly and used as the GEC and/or an EGC, solid AL conductors do not present the same problems.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/2/06, 10:27 AM
Paul W. Abernathy's Avatar
RRAY,
I have seen single strand AL up to a #8 AWG before...but it is not something you will find everyday...thats for sure.
Paul W. Abernathy,CMI,CPI,CME
Old 6/12/06, 5:38 PM
I have never seen 6 or 4 al solid that you would need for 40 and 50a circuits. OTOH The real issue with al is the termination style not the wire.
Actually I haven't seen 8 solid al either but even then it could only be used as a single conductor, not in a cable or raceway.
Old 6/14/06, 7:47 PM
Brian E. Kelly's Avatar
Drywer circuit today.
Old 6/14/06, 8:22 PM
Dale Duffy's Avatar
Another builder saving a couple bucks........... ...as usual.
Old 6/14/06, 8:49 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is some aluminum wiring I found today.
Old 6/14/06, 11:54 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I love finding stuff like that! Easy to write up and you feel like you might have saved someone from an electrical fire. If they fix it,that is.
Old 6/15/06, 9:15 PM
Charles,
Still amazes me when I see things like that.......just a lack of concern on the person that did it......they are probably still saying...well it ain't burnt down yet.....Git er Done.....
Makes me wanna SLAP the home owner....
James- You are right........IF they fix it......could not agree more.
Old 6/17/06, 12:41 PM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is online now
I have never seen single-strand solid aluminum larger then #10, and I must have installed miles of aluminum wire back in the 70's. Maybe it was a New Jersey thing, but all aluminum conductors larger then #10 were to my recollection multi-stranded SEU/SER.
"By three methods we may learn wisdom: First, by reflection, which is noblest; Second, by imitation, which is easiest; and third by experience, which is the bitterest." -Confucius
Certified Master Inspector (2007)
Member, International Assoc of Certified Home Inspectors (InterNACHI)
Member, International Code Council (ICC) - Certified Residential Combination Inspector
Square-One Inspection "Assurance begins here"
Aluminum Wiring jhagarty Electrical Inspections 23 10/5/07 3:56 AM
Aluminum Wiring acox Electrical Inspections 4 8/27/07 12:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Reporting Aluminum Wiring Richard Seay Electrical Inspections 3 2/28/07 5:27 PM
Aluminum Wiring homeowner001 Electrical Inspections 36 7/7/06 2:08 AM
