Old 4/7/11, 5:04 PM
Greg Strump Greg Strump is offline
Default Aluminum Wiring
In the attached pics it appears the there is aluminum wire leading to the 220 circuits. I was surprised to see this since the house was built in 1984. What recommendations would you suggest?
aluminum-wiring-100_4570.jpg   aluminum-wiring-100_4573.jpg   aluminum-wiring-100_4574.jpg
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/7/11, 5:23 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Aluminum Wiring
Aluminum wire for the 220 circuits are fine....
It is the Panel that is BAD
Federal Pacific Stab-Lok
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 4/7/11, 5:27 PM
Jeffrey R. Jonas's Avatar
Yes, "stranded" AL conductors are okey-dokey!
Old 4/7/11, 9:43 PM
Thanks for the responces, but why do insurance companies frown on aluminum wiring in the house?
Old 4/7/11, 9:58 PM
mnahrgang's Avatar
Originally Posted by gstrump View Post
Thanks for the responces, but wire do insurance companies frown on aluminum wiring in the house?
Only solid aluminum, and then only certain companies, and under certain circumstances.
Mark Nahrgang
www.HeyMark.info
Old 4/7/11, 10:20 PM
Brad Brinke Brad Brinke is offline
Greg, please don't take this the wrong way, but where did you train for this profession?
Inspecting Norfolk and Hampton Roads
www.procraftinspections.com
Energy Audits in Norfolk
www.procraftgreen.com
Rule of thumb... (there's always exceptions)...
Solid AL = Bad
Stranded AL = Okay
Old 4/7/11, 10:44 PM
Christopher Currins's Avatar
In Illinois we are required to:
"Report on the presence of solid conductor aluminum branch circuit wiring"
Christopher Currins
Certified, Licensed
Old 4/7/11, 11:01 PM
mwolff mwolff is offline
FPE stab-lok panel, known to have problems.
Conduit through concentric knock out, no connector, improper install.
Garbage in bottom of panel.
Old 4/8/11, 4:50 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
I agree with the others, this panel has issues but the stranded Al isn't one of them. Personally I would change out any FPE panel immediately.
Old 4/8/11, 7:33 AM
Barry Adair's Avatar
Fire potential, they mitigate liability by not insuring until upgrades or rewire are completed, once issues are identified. Odds in their favor of fewer loss payouts and more profit in their pocket.
This article may provide a better understanding...
Regardless of where or how much training/experience one has, we all can and should continue to learn and assist whenever possible.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/8/11, 8:02 AM
Jeff Zehnder Jeff Zehnder is offline
Please Note: Jeff Zehnder is a non-member guest and is in no way affiliated with InterNACHI or its members.
The following is what the insurance industry states to place in all commercial clients insurance inspection results that have aluminum wire of suspect panels...
Federal Pacific brand panel- You have a Federal Pacific electrical panel or panels installed in your building. It has been found that some of these panels have failed to provide proper protection, as they may have a tendency to overheat and cause a fire. To reduce this exposure it is recommended that a qualified electrical contractor replace Federal Pacific brand panels with another brand that has a current UL listing and which provides improved protection and reliability.
(or)
Zinsco Electrical brand panel- You have Zinsco electrical panels in your building. Many Zinsco panels contain a design flaw which can cause arcing and subsequent overheating. Long term exposure to this heat can cause the breaker to fuse to the bus bar, making it impossible to remove. Even worse, it can cause the breaker's contacts to fuse together, thus preventing the breaker from tripping even in an over current situation, thereby causing a potential fire hazard. To reduce this exposure a qualified electrical contractor should replace Zinsco brand panels with another brand that has a current UL listing and which provides improved protection and reliability.
As far as aluminum branch circuit wiring they ask that it be noted in any insurance reporting and since that panel would have to be more than 30 years old they require replacement.
Jeff Zehnder
Cary, NC
Old 4/8/11, 10:43 AM
Does that hold true for residental as well?
Old 4/8/11, 10:47 AM
Great article thanks Barry!
Old 4/8/11, 4:01 PM
(or)
Jeff Zehnder
Cary, NC
Are you saying that by default all aluminum branch circuit wiring is more than 30 years old?
Aluminum Branch Wiring update jshishilla Florida Inspectors 6 3/16/11 11:11 PM
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Aluminum Wiring jhagarty Electrical Inspections 23 10/5/07 2:56 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
