Old 12/4/09, 6:30 PM
Nick Gromicko's Avatar
Default Aluminum Wiring: Please proof this new inspection article.
http://www.nachi.org/aluminum-wiring.htm
Find a Home Inspector
Find an InterNACHI certified Utah Home Inspector (and anywhere else in North America)
Old 12/4/09, 7:01 PM
James H. Bushart's Avatar
Default Re: Aluminum Wiring: Please proof this new inspection article.
Under your "Options for Corrections" you had better make a reference to the appropriate electrical code for the area where the correction is being made for not all of your solutions are universally acceptable.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 12/5/09, 7:12 PM
gbeaumont's Avatar
Hi Nick, here's my thoughts (in red)
Aluminum Wiring
By Nick Gromicko, Rob London and Kenton Shepard
Between approximately 1965 and 1973, Single strand aluminum wiring was sometimes substituted for copper branch-circuit wiring in residential 15 and 20 amp electrical systems due to the sudden escalating price of copper. After a decade of use by homeowners and electricians, inherent weaknesses were discovered in the metal that lead to its disuse as a branch wiring material. Although properly maintained aluminum wiring is acceptable????, aluminum will generally become defective faster than copper due to certain qualities inherent in the metal. Neglected connections in outlets, switches and light fixtures containing aluminum wiring become increasingly dangerous over time. Poor connections cause wiring to overheat, creating a potential fire hazard. In addition, the presence of aluminum single strand wiring may void a home’s insurance policies. Inspectors may instruct their clients to talk with their insurance agents about whether the presence of aluminum wiring in their home is a problem that requires changes to their policy language.
Aluminum as a Metal
Aluminum possesses certain qualities that, compared with copper, make it an undesirable material as an electrical conductor. These qualities all lead to loose connections, where fire hazards become likely. These qualities are as follows:
  • higher electrical resistance. Aluminum has a higher resistance to electrical current flow, which means that, given the same amperage, aluminum conductors must be of a larger diameter than would be required by copper conductors.
  • less ductile. Aluminum will fatigue and break down more readily when subjected to bending and other forms of abuse than copper, which is more ductile. Fatigue will cause the wire to break down internally and will increasingly resist electrical current, leading to a buildup of excessive heat.
  • galvanic corrosion. In the presence of moisture, aluminum will undergo galvanic corrosion when it comes into contact with certain dissimilar metals.
  • oxidation. Exposure to oxygen in the air causes deterioration to the outer surface of wire. This process is called oxidation. Aluminum wire is more easily oxidized than copper wire, and the compound formed by this process – aluminum oxide – is less conductive than copper oxide. As time passes, oxidation can deteriorate connections and present a fire hazard.
  • greater malleability. Aluminum is soft and malleable, meaning it is highly sensitive to compression. After a screw has been over-tightened on aluminum wiring, for instance, the wire will continue to deform or “flow” even after the tightening has ceased. This deformation will create a loose connection and increase electrical resistance in that location.
  • greater thermal expansion and contraction. Even more than copper, aluminum expands and contracts with changes in temperature. Over time, this process will cause connections between the wire and the device to degrade. For this reason, aluminum wires should never be inserted into the “stab,” “bayonet” or “push-in” type terminations found on the back of many light switches and outlets.
  • excessive vibration. Electrical current vibrates as it passes through wiring. This vibration is more extreme in aluminum than it is in copper, and, as time passes, it can cause connections to loosen.
Identifying Aluminum Wiring
  • Aluminum wires are the color of aluminum and are easily discernable from copper and other metals.
  • Since the early 1970s, wiring-device binding terminals for use with aluminum wire have been marked CO/ALR, which stands for “copper/aluminum revised."
  • Look for the word "aluminum" (or the letters AL) on the plastic wire jacket. Where wiring is visible, such as in the attic or electrical panel, inspectors can look for printed or embossed letters on the plastic wire jacket. Aluminum wire may have the word "aluminum," or a specific brand name, such as "Kaiser Aluminum," marked on the wire jacket. Where labels are hard to read, a light can be shined along the length of the wire.
  • When was the house built? Homes built or expanded between 1965 and 1973 are more likely to have aluminum wiring than houses built before or after those years.
Aluminum wiring should be evaluated by a qualified electrician who is experienced in evaluating and correcting aluminum wiring problems. Not all licensed electricians are properly trained to deal with defective aluminum wiring. The following corrective actions may be taken:
  • Rewire the home with copper wire. While this is the most effective method, rewiring is expensive and impractical, in most cases.
  • Splice the aluminum wire to copper wire at the connections using approved wire nuts (called "pigtailing") (I believe this is wrong the only listed method I know of is "Copalum" crimps). This method is only effective if the connections between the aluminum wires and the copper pigtails are extremely reliable. Pigtailing with some types of connectors, even though they might be presently listed by Underwriters Laboratories for the application, can lead to increasing the hazard. Also, beware that pigtailing will increase the number of connections, all of which must be maintained.
  • Replace certain failure-prone types of devices and connections with others that are more compatible with aluminum wire.
  • Remove the ignitable materials from the vicinity of the connections (Not practial).
  • All connections should be checked and an anti-oxidant paste applied (not correct).
  • Copalum crimps can be installed. Although effective, they are expensive (typically around $50 per outlet, switch or light fixture).
In summary, aluminum wiring can be a fire hazard due to inherent qualities of the metal. Inspectors should be capable of identifying this type of wiring.
Nick you need to stress this only affects single strand aluminum conductors not multi-stranded
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 12/5/09, 7:27 PM
Brian E. Kelly's Avatar
I would not add any AMP numbers to the article myself. I often see single strand AL wiring in larger sizes serving AC units/water heaters/ etc.
I also believe there are more repair connectors available today.
http://www.alcopstore.com/index.asp?...ATS&Category=2
Old 12/5/09, 8:14 PM
Joe Funderburk, CMI's Avatar
Have AFCI's become an accepted method of adding protection?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/6/09, 6:50 PM
Allen L. Catterton's Avatar
Allen L. Catterton Allen L. Catterton is offline
More and more I am seeing that the major insurers, especially here in Florida, will refuse to write a homeowner’s policy on a home with aluminum branch circuit cabling. The polices can usually be written on the secondary market but owner/ buyer should be informed that anything other than total replacement of the cabling is generally considered a “quick fix” and will still lead to high and sometimes exorbitant insurance rates. Would you want to include a paragraph in your article regarding insurability?
Old 12/7/09, 7:28 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
I don't know of any insurance companies in Florida that will keep a policy in force once they found out the home has aluminum branch circuits. Most of the electricians I know won't use the crimps. They also will deny a claim if it is a fire and the home has aluminum branch circuits. They say that makes the problem worse then it originally was.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 12/7/09, 1:08 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
I don't know of any insurance companies that will keep a policy in force once they found out the home has aluminum branch circuits.
Greg,
There are tens of thousands of insurance policies in effect. Yes, this is with single-strand aluminum wiring.
Maybe things are different in Florida...
Old 12/7/09, 2:42 PM
Rob London Rob London is offline
Thank you Gerry, I made most of those corrections. The article has been updated with some information I got from a company that specializes in aluminum wire repair, as well as the CPSC. I'll try to find the answers to the other issues. I sent the article off to a specialist to look at, we'll see what he has to say.
Researcher and Technical Writer, InterNACHI
Old 12/7/09, 2:58 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Thank you Nick, I add live links to articles in my HI reports, which benefit my Client with greater knowledge than I can give them in a short time, and make me look good. Keep up the good work. A request, Looking for a good GFCI article.
Old 12/7/09, 4:25 PM
Glad you like them
Putting it on the list
Old 12/7/09, 4:32 PM
Thanks NACHI. Looking for a good Ghosting article too!
Theodore Roosevelt
Joe Funderburk, CMI
Knob and Tube Wiring: Please proof this new inspection article. gromicko Electrical Inspections 5 7/21/09 8:19 AM
Aluminum Wiring jhagarty Electrical Inspections 23 10/5/07 2:56 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 5 3/25/07 10:41 PM
