When upon discovering aluminum wiring in the electric panel. How many of you go as far as pulling a few electrical outlets and checking for signs of arcing? Or do you just make the note of your observation and recommend and evaluation by a licensed electrician?
I personally am not an electrician and do not pull outlets in fear of disturbing the connections that may already be loose. How about you? John Buckley 20/20 Home Inspection of NJ 1-888-798-5190 JOHN@THE2020HOMEINSPECTOR.COM WWW.THE2020HOMEINSPECTOR.COM WWW.NJMOLDTEST.COM |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I do not pull outlets.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
I a retired Sparky do not open outlets.
I report what I visually see . I do a visual inspection as per My SOP.... Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Like the rest of the guy's that answered, I do not pull the cover's off and just report what I see.
It doesn't really matter if you see aluminum, copper, or whatever type of wire in the panel, you should not be opening any receptacles, switches, or any fixtures for that matter. The is getting to technically exhaustive and could open a can of worms you don't want to be opened.
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
The reason I started this poll was because I was scalded by a sellers agent over reporting aluminum wiring without checking if that outlets were properly pigtailed. she mentioned that her inspectors remove outlets during all of her inspections. I know she was trying to get my dander up over rocking her boat, but hey I did my job. I wanted to get a feel if anyone else was pulling outlets. Thanks for your input.
How did you report the aluminum wiring? They do have a point about whether or not the devices were pigtailed even if it's outside of the scope of your inspection. |
Maybe so, but that's the electricians job to determine... You did your job. If the selling agents inspector pulls plugs, you've got to wonder what he's not doing... Frankly I wouldn't even believe her... She probably heard something on those lines from an electrician who was doing a followup inspection for her sometime.
The observation went like this. Solid strand Alumnin wiring present in localized circuits throughout dwelling. Failures associated with Aluminum wiring have been known to be a possible fire hazard and should be evaluated by a licensed electrician. I think that was putting it lightly... how are you guys calling this out?
Here's what I put in my reports:
Solid aluminum (AL) conductors were noted at one or more branch circuits in the electrical panel. AL wire has a higher expansion and contraction rate (approx. 30%) than copper and over time may become loose at its connections causing overheating or arcing. As a result, only receptacles and outlets approved for use with AL should be used (CO/ALR). It is strongly recommended that a licensed Electrical Contractor review the AL branch circuit wires in the home for approved connections at the receptacles and switches. Any necessary corrections or repairs should be made in accordance with current electrical standards. I am interested to hear comments. "A man cannot be truly grateful and remain unhappy"
Why strongly? Are your other recommendations "softly"? If you take it out, it leaves not gray area. CALL a licensed electrician. Just my 2 cents, the rest is written very well. Congrats Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Robert ..
Thanks for your post's many have been helped by them . Please keep helping . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
North Carolinas recomended wording for reports follows:
Home Inspection Report & Summary Page – Recommended language for Aluminum Wiring. Single strand aluminum wire is present on 120 volt branch circuits in this house. This single strand, branch circuit aluminum wire was used widely during the 1960s and 1970s. According to reports published by the U.S. Consumer Product Safety Commission (CPSC), problems due to overheating at the connections between the wire and devices such as switches, outlets, and light fixtures may have been responsible for house fires. It is recommended that the circuits using single strand aluminum wiring be evaluated and modified as may be deemed necessary by a licensed electrical contractor who is familiar with the problems inherent in this type of wiring. For more information on aluminum household wiring, refer to the National Electrical Code and the C.P.S.C. booklet "Repairing Aluminum Wiring." The toll-free hotline number for obtaining this booklet is 1-800-638-2772, or you can visit: http:// |
| Aluminum Branch Wiring update | jshishilla | Florida Inspectors | 6 | 3/16/11 11:11 PM |
| Evaluating your home's wiring system | mcyr | Electrical Inspections | 0 | 12/30/09 1:31 PM |
| Aluminum Wiring | jhagarty | Electrical Inspections | 23 | 10/5/07 2:56 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
