Old 12/8/10, 8:25 PM
Sean Fogarty's Avatar
Default AM I missing somthing here?
Look at the gfci breaker
I know its not right, but what did they do????
Shouldn't the hot wire be installed under a different screw or is this normal.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/8/10, 8:28 PM
Default Re: AM I missing somthing here?
Larry Kage, CMI
231 929 3525
Old 12/8/10, 8:42 PM
Thanks.
I am used to seeing them without the neutral being stuffed in with the pigtail. Older panel and breaker.
865-256-5397
Old 12/8/10, 9:07 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Originally Posted by lkage View Post
Why would they show a splice on the load neutral? Typically they connect directly to the CB making this graphic somewhat confusing.
Old 12/8/10, 9:09 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Sean, just a tip.... Change the name of the picture, so that no one could find the location from the filename.
Old 12/8/10, 9:51 PM
This is the exact reason for my confusion! Like I said it was an older breaker 16 years exactly. I personaly have never seen an installation this way.
865-256-5397
Old 12/8/10, 9:52 PM
Yeah, I wanted an answer and did not want to waste time while doing the report.
865-256-5397
Old 12/8/10, 10:42 PM
While the image is not what normally happens...it is also technically correct regardless. Nothing in the NEC would prohibit a contractor from splicing a "MISTAKE" they might have made in cutting off the neutral [grounded conductor] too short and adding that pigtail. While not the norm...still compliant never the less.
In regards to the graphic larry posted......I never actually looked at the original posters picture...lol...sorry
Paul W. Abernathy
Old 12/8/10, 10:50 PM
ok.....now I look at this image and something strikes me as odd. The neutral [grounded conductor] should not be jamed in with the GFCI grounded jumper. I believe their should be another lug on that breaker that is not being used. If this is the case the GFCI will not function as intended when the intent is needed......say that 5 times in a row why don't ya !
But alas.....my eyes may be screwing with me
Paul W. Abernathy
Old 12/8/10, 11:06 PM
agallatin agallatin is offline
Hi Paul , the insulated conductors loo a little over striped. IMO
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 12/8/10, 11:12 PM
lol...yeah I was holding my breath on that one as I doubt it meets the technical concept of "encircle"...lol...but hey they atleast tried.
Paul W. Abernathy
Old 12/8/10, 11:14 PM
lol....I just read your statement again...lol.....I thought you meant the stripes of BLACK marker on the grounded conductors in order to ATTEMPT to re-identify them...lol.....man I gotta read the posts better as I am multi-tasking tonight.
Paul W. Abernathy
Old 12/8/10, 11:24 PM
Stephen W. Stanczyk's Avatar
Paul...... put down the burger and slowly back away.. or are you getting in shape to fit in your Santa outfit?
Stephen Stanczyk
Old 12/9/10, 4:42 AM
Ahhh, so the CB is so old that it came with two factory installed pigtails.
Old 12/9/10, 7:17 AM
Is this the correct answer???
Did they actually do it this way, because I thought it was stuffed in the hole, which is why it looked strange.
Before my time I guess.
865-256-5397
Missing Gutter extensions tturner Exterior Inspections 1 9/19/10 4:18 PM
Can you spot whats missing? belliott Inspecting HVAC Systems 13 2/21/09 11:20 AM
What's missing here? jtedesco1 Electrical Inspections 10 12/19/07 8:11 PM
Water Heater label missing rnewman1 Plumbing Inspections 3 9/19/06 6:15 PM
