Steven Brewster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey folks,
Has anyone seen these connectors used on aluminum wired homes? I have been asked to inspect a home with known aluminum wiring (split level) and the most cost effective solution would be to use these connectors. Any feedback as to costs, effectiveness, problems? Any input would be greatly appreciated. Thanks, Steven |
You will need to have what they call, COPALUM , connectors.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I defer these types of Inspections to an Electrician.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I refer as well, but was hoping that one of the electricians that usually post could give me their opinion on this type repair. I realize that replacement is the best alternative but do the COPALUM crimp connectors work well, or does the installation cause other problems? Just wanted some input from someone who has installed these connectors.
Steven |
Best website I have ever seen on aluminum wiring and the use of Copalum crimps. Enjoy and share.
http://www.inspect-ny.com/aluminum.htm Here's another one with "pictures" http://www.alwirerepair.com/copalum_crimp_method.htm Last edited by dedwards; 5/3/06 at 10:48 PM.. |
It must be done properly, therefore it should be defered to verify the integrity of the installation.
Thanks guys.
I am in the minority opinion here but I think if you don't have symptoms and you don't screw with it, aluminum wire is not that big a problem. I back that up with the lack of scare stories on the news today. I think all the sloppy aluminum jobs that were doomed to fail have already failed and the others will be OK.
The fact is, if the electrican did a good job and the homeowner didn't screw with it, most of the millions of aluminum wired houses never had a problem. Has Inspect-NY come up with any "new" stories? That article is older than some of our readers here. |
You're the "expert" here Greg. Your opinion matters, not only to us, but the public as well.
As generalists, we are obligated (or if you prefer - "compelled") to defer these situations to the experts. When you offer this opinion to our client, you relieve us of the potential liability. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Since you have a Zinsco electrical panel with single strand aluminum branch circuit wiring "I'm Compelled" to refer this installation to a licensed electrician, blah, blah. It is compelling Jeff...... |
Greg,
I have to agree with you. I routinely inspect homes here on the Gulf Coast of FL that are older homes that may have been had updated electrical systems more than once. I can honestly say that I have yet to find a home with aluminum wiring that has had any signs of arcing or overheating. Many of them have aluminum systems well over 30 years old and my standard response to the client is that the home has been here without incident for ____ years but also tell them what they should look for in the way of symptoms of problems. The biggest problem we run up on is insurance companies, realtors and as you said the horror stories that have been circulating for years. Many insurance companies will not take on a customer if they find out the home has aluminum wiring. I have known of several realtors that will not list a home if they find out it has aluminum wiring. Unfortunately it is hard to put the toothpaste back into the tube once the public has come to believe something. Equally difficult is when you have electricians who do not agree on the issues of AL wiring. Some will say the whole sytem should be pulled and replaced while there are others like yourself who use a more common sense approach and look at the evidence rather than the hype. Thanks for your input. |
The CPSC provided the following information as early as 1974. Use this for your reports.
May Is National Electrical Safety Month: Good News for Homeowners - Aluminum Wiring Fix ... CPSC Invites Offerors For Aluminum Wire System Safety Standard CPSC Safety Recommendations For Aluminum Wiring In Homes CPSC Sets Aluminum Wire Hearings - Explore Potential Fire Hazards "Repairing Aluminum Wiring" |
Like I said, most of these reports are older than a lot of our posters.
| Hook 2 appliance connectors together? | jfunderburk | Inspecting HVAC Systems | 6 | 9/8/07 4:24 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 4 | 3/25/07 11:41 PM |
| Aluminum Connectors | bsmith | Electrical Inspections | 9 | 5/9/06 12:01 PM |
| Crimp connectors at breakers | syared | Electrical Inspections | 55 | 2/27/06 12:28 PM |
