Old 3/7/11, 12:06 AM
wvaidic wvaidic is offline
Question Another Al Wiring Question
Is Aluminum wiring for the service entrance wires okay? I believe only single strand aluminum branch wiring is a problem, but want to confirm.
Thanks
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/7/11, 12:17 AM
Stephen W. Stanczyk's Avatar
Default Re: Another Al Wiring Question
Not a problem. I would bet that 95% of the homes I inspect are aluminum. Copper is a rarity.
Stephen Stanczyk
Old 3/7/11, 12:36 AM
James R. Szczesny's Avatar
James R. Szczesny James R. Szczesny is offline
true,true
J.Szczesny
4 Seasons Home Inspections
Washington State Inspector # 711
800 5th Ave #101-385
Seattle, Wa 98104
(206)391-0285
online @ www.4seasonsinspects.com
email @ info@4seasonsinspects.com
toll free cal @ 866-512-9972
"For the best protection,
get the right inspection"
Old 3/7/11, 5:19 PM
John M. Walker John M. Walker is offline
Multi strand aluminum wiring is still to code if used for a dedicated 240 VAC appliance circuit.
Old 3/7/11, 5:20 PM
Copper is the preferred feeder wire for manufactured homes.
Old 3/11/11, 8:02 AM
Thanks for all of the answers.
So, if you found aluminum as feeder wire for a manufactured homes you would write it up as a defect?
Old 3/11/11, 11:55 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Make sure aluminum SEC's have anti-oxidant paste installed at the lugs. Some manufacturer's use aluminum lugs, but the set screws are made out of steel. The paste helps prevent galvanic reaction between two dissimilar metals.
Stranded AL SEC's are perfectly fine and expect to find them everywhere.
Old 3/11/11, 3:03 PM
Jim Port Jim Port is offline
Unmoderated Guest
While a good practice, the use of anti-oxidant paste is not required by the NEC, unless called for by the wire manufacturer.
Old 3/11/11, 5:37 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
I agree, you shouldn't be writing this up unless you know for sure that the specific lug manufacturer requires an anti-ox compound. To the best my knowledge most actually do not require it.
Old 3/11/11, 8:19 PM
mwolff mwolff is offline
Aluminum is fine if sized properly. What could be a problem is the type of insulation on the wire. Where conductors enter the residence they should have a temperature rating of 90C. In other words the insulation marking should have an HH rating... THHN XHHW. The higher rating is for a better fire rating. Many older homes will not have this type of insulation, but newer construction should. There again electrical can be case sensitive according to the AHJ.
Old 3/11/11, 11:09 PM
Mark what do you mean about a better fire rating and insulation type?
Old 3/12/11, 11:16 PM
Wendy -
Aluminum stranded wire is probably the most common service entry wire in use in many areas. NO it would not be written /Just identified.
Old 3/13/11, 12:35 AM
Not all insulation types are the same. Such as thermoplastics or rubber. The type of insulation or coating on the wire will give it a specific temp.(heat) rating. By having a higher temperature rating it would be less likely to melt down the insulation in high current situations, thus a better fire rating.
For instance, certain direct burial conductors(service lateral) could be used up to the meter. If enough was left over after making the connection to the meter, we would just use the same wire to go from the meter to the indoor panel. But now that the wire has entered the building it should have a higher insulation rating.
Not sure if this could ever be written up though as I am quite new to the home inspection world.
Old 3/13/11, 4:00 PM
Unmoderated Guest
Direct burial cable used to feed a service are not for use inside the house.
Old 3/13/11, 7:09 PM
I'm not understanding this concept. If the conductor is properly sized for it's connected load why would the type of insulation make any difference?
Got a letter from ASHI's President today. gromicko General Inspection Discussion 55 12/12/10 11:51 PM
Panel box wiring..Question dnasser Electrical Inspections 8 10/30/10 9:17 AM
Top Ten Wiring Hazards Threaten Life and Property jtedesco1 Electrical Inspections 3 9/2/08 5:15 PM
Top Ten Wiring Hazards jtedesco1 Electrical Inspections 6 9/1/08 8:26 PM
Panel Surround / Exposed Wiring Question thance Electrical Inspections 11 2/19/08 9:06 PM
