Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 4/6/08, 7:33 PM
Richard D. Slocum's Avatar
Richard D. Slocum Richard D. Slocum is offline
Default Another amazing installation.........
Supposedly this was done by a licensed electrician and sign off by the City inspector. ( this was a flip) # 14-2 wire out of the main service panel through a weather head, tied into 2 awg AL triplex , only 8 feet off the ground running through the back yard then re-attached to #14-2 and run through a pipe into the garage. This cannot be right ! Right?
The #14-2 w / ground was typical interior rated NM (Romex) . Also, this # 14 wire was protected by a 20 amp breaker in the panel.
How would you word this in a report , besides just saying that it was FUBAR and recommending eval by a qualified electrical contractor?
another-amazing-installation-wiring-garage-1.jpg   another-amazing-installation-wiring-garage-2.jpg   another-amazing-installation-wiring-garage-3.jpg
Rick Slocum
NACHI # 04072697
Elizabeth CO 80107
ABSOLUTE Home Inspection Service
Old 4/6/08, 7:40 PM
Mike Whitt's Avatar
Default Re: Another amazing installation.........
It is really hard to tell from the picture but the branch circuit supplying the garage seems to be as high as the service drop so in one is bad the other is bad.
20 amps on a #14 is bad but other than that there is nothing wrong with the installation. It is okay to upsize a conductor but it is wrong to down size one.
Old 4/6/08, 7:52 PM
Thanks Mike. Actually the service drop is quite a bit higher, hard to tell from the pic though. So , is it ok for the #14 wire to be exposed to the elements like that? And should the point where the wire enters the garage also run through a weather head?
Rick Slocum
NACHI # 04072697
Elizabeth CO 80107
Old 4/6/08, 8:23 PM
Mike Whitt's Avatar
That could be debatable as they are supposed to be sunlight resistant
Yes or something equivalent
Old 4/6/08, 8:26 PM
Thanks Mike ! Appeciate the help as always.
Rick Slocum
NACHI # 04072697
Elizabeth CO 80107
Old 4/12/08, 11:35 AM
Bruce Erny Bruce Erny is offline
Please Note: Bruce Erny is a non-member guest and is in no way affiliated with InterNACHI or its members.
If 14/2 is NM-B than the exposed wire is thhn/thwn and is good per code.
20 amp breaker is not to code. Must be 15 amp.
Grounded conductors cduphily Electrical 144 12/22/08 7:32 AM
Siding installation and electrical service equipment jtedesco1 Exterior 1 12/16/07 5:59 PM
Question about improper installation cbell1 Exterior 3 10/24/07 10:13 PM
Bonding wire installation requirements ?? rnewman1 Electrical 7 7/31/06 3:31 PM
Window installation jmichalski Exterior 17 1/24/06 10:42 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
