This one powered the pool motor, outlets, pool lights, heater and hot tub.
See anything wrong??? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What size breaker is protecting the feeders? Is the neutral terminal isolated from the panel? It's difficult to determine from your picture.
30 amps
It was difficut for me to see and I was there. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Looks like the breakers might be from different manufacturers. You would need a load calculation to determine if the 30 amp feeder is of adequate size. Is this at/on a separate structure? If so I see no grounding electrode conductor so I would assume that there is no grounding electrode system installed.
hot tub pool lighting pool pump motor Gas fired pool heater all in one panel. I would think just the hot tub itself would do it, but out of curiosity what size breaker and wire would be needed. This panel was on the back of the home and the ground was present, just not connected in the panel. I found it loose and lying in the grass. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
If the panel wasn't mounted to a separate structure then no GES is required. There is an insulated EGC in the feeder which is required to ground the panel.
As far as load goes, without specific nameplate ratings from the equipment you cannot answer the question as to where or not a 30 amp feeder is adequate. |
It's pretty common to find a 40 amp feed on a system with multiple pumps and lights. 30 amps may be sufficient in this case.
If the heater is electric (which is very unlikely), it would need a larger circuit. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If the neutral bar is isolated and ground bar is bonded, which they both appear to be (not sure), is there actually anything wrong here?
IMO nothing that is readily identifiable from the photo.
Interesting....
The circuit for the pool lights had tripped and wouldn't reset, which was the main issue at hand. The sizing was somthing uncommon for me to see, especially with all that was on it. We will see what the next guy has to say when they come to replace the breaker or correct the issue. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
What caused it to trip??
It was already tripped Chirs. Its not my job to guess with pool lights, but if I had to I would start with a faulty breaker.
Maybe it got too hot while running all the other stuff. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Not likely.
There's probably a ground-fault in the lighting circuit, and the breaker is doing it's job. This often happens when the seal for the pool light fails. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Maybe the breaker was doing it's job. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
what about double taps and wrong colored wires. hot and neutral same color as some wire going into breakers. i know they arent the exact same wire, but souldnt they be different colors.
| Pool Executive Charged in Drain Death | jhagarty | Ancillary Inspection Services & Additional Topics | 1 | 7/23/08 11:15 PM |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
| It's time for Professional Pool Inspections | Revel L. Thom | Ancillary Inspection Services & Additional Topics | 13 | 7/26/07 10:50 AM |
