Here's the situation:
Hall bath GFCI outlet protects the Master bath outlets. Using GFCI tester in the Master bath the GFCI outlet in the hall bath trips cutting off power to the master bath, BUT, there is still power at the "tripped" hall bath GFCI outlet. Using the tester and also the test button on the GFCI outlet in the hall bath the GFCI outlet trips but does not diconnect power. What's up with that? Wired wrong? Thanks Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
Yes, wired wrong, line and load reversed.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Cal Huntsman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Its more than likely wired back wards if its an older GFIC the new ones wont work at all if wired back wards.
| GFCI Question | mdavis5 | Electrical Inspections | 4 | 9/12/07 8:22 PM |
| GFCI Question | jvogan | Electrical Inspections | 4 | 8/25/07 2:28 PM |
| Adequate service size....oh, and a GFCI question | ksherstobetoff | Electrical Inspections | 13 | 2/8/07 1:18 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
| GFCI Question | gporter | Electrical Inspections | 13 | 2/6/06 9:21 PM |
