This is not my photo, I borrowed it from a colleague.
Is it true that, for this panel, the ungrounded conductors of a multi-wire circuit should not be connected to adjacent breakers 1-2 because they are on the same bus? I thought multi-wire ungrounded conductors of the same circuit should always be connected to adjacent breakers, with a tie-bar between the breakers |
Woops, the file size of the photo was too big. It's an FPE Stablok.
Here it is ( I think).
Hard to see in the photo because the breakers are all black. Keep in mind that a pair of half sized breakers will contact the same bus, and adjacent full sized breakers will contact opposite busses. The two hot wires of a multi-wire circuits must originate from opposite busses.
| Easy question | brepanshek | Electrical Inspections | 8 | 3/19/07 9:43 PM |
| Ground wire in neutral bar, neutral to breaker, hot to ground? | rmc3inspection | Electrical Inspections | 4 | 8/1/06 9:44 AM |
| Smokes on AFI circuits | lprinzi | Electrical Inspections | 9 | 7/6/06 9:12 PM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
