Old 10/3/07, 11:16 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
Default Anyone ever seen this before?
Found this today in a Federal Pacific with Stab-locs
What reason could anyone have for soldering the wires onto the buss? Does it somehow provide power to the lower half of the panel? (assuming the lower half didn't already have power)
Bruce
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 10/3/07, 11:17 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Anyone ever seen this before?
Split Main Panel
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/3/07, 11:20 PM
So it's OK?
Bruce Thompson
NACHI 06081394
tdietrich1's Avatar
Odds are they are 'crimped'. The dot in the center looks like pressure was applied to fix the cable into the bus.
tom
tdietrich1's Avatar
Originally Posted by bthompson1
So it's OK?
Federal Pacific with Stab-locs?
Old 10/3/07, 11:21 PM
Well not THAT part.
Actually there is a double-tap as well, so I'm already calling for an electrician's eval. I explained to the client about FPE and will send him some further information.
Bruce Thompson
NACHI 06081394
Old 10/3/07, 11:23 PM
tdietrich1's Avatar
Well not THAT part.
Understood.
Split buses are common in 'older' houses. The photo you show has no discoloration, or damaged insulation. So it looks solid. However, you have enough to defer to a qualified electrician for further evaluation/replacement.
tom
Old 10/3/07, 11:27 PM
Originally Posted by tdietrich1
Understood.
tom
Obviously I've never run across one of these but I don't really understand why you would do this. So did the installing electrician somehow split the buss or would it have come from the factory like that?
Ignorantly,
Bruce
PS thanks for all of the quick responses
Bruce Thompson
NACHI 06081394
Old 10/3/07, 11:31 PM
Marc D. Shunk's Avatar
Banned
That's the way it came from the factory. It wasn't cobbled together like that in the field. It came pre-cobbled.
Old 10/4/07, 6:49 PM
Robert J. OConnor's Avatar
Some older panels were done that way with a split buss to save the expense of a larger main breaker for the entire panel. There just had to be no more than 6 switches/breakers to completely shut power off. So the top part of the panel would have the breakers for the larger circuits (e.g. stove, dryer), and one breaker that fed the lower part of the panel intended for more lightly loaded circuits. No main breaker ... just an additional breaker to feed the lower buss, which was less expensive.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
www.reporthost.com/-rjo
Old 10/5/07, 3:42 AM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bruce :
this type of breaker box is split panel and it was pretty common in 50's to i think about early 70's after that they went away
anyway for that type of split panel it willbe useally i will say useally be a 100 amp service but few case i ran into are 60 amp service as well
the other thing i will like to give few guys here a head up that one part of the split buss is hot all the time regaurding if you did turn off all the breakers the bussbar on upper [ useally ] part will stay engerized until the meter yanked out or cut the service drop [ or riser ]
Merci, Marc
