Old 11/4/06, 4:43 PM
jweinberg's Avatar
jweinberg jweinberg is offline
Please Note: jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Anything wrong with this?
Anything wrong with this???
50 amp bridged breaker (electric range I believe) with appropriately sized conductors. However, one is copper and the other is aluminum.
I can only assume that the copper distribution wire was short (or had to be replaced) so they spliced a short pigtail to ONE side with aluminum stranded. Again, can only assume that they used Aluminum because that is what they had in the truck?????
Can't think of any reason this would be called out but wanted to get a second opinion before submitting my report.
Any input is welcome.
Old 11/4/06, 4:49 PM
Jeffrey R. Pope's Avatar
Default Re: Anything wrong with this?
The CU to AL splice would be a potential point of issue. It must be an approved connector, but it almost looks like a split-bolt connector (which would not be proper).
Verification of the connection would be warranted. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/4/06, 5:03 PM
Unmoderated Guest
Actually a correct CU/AL split-bolt is one of the proper methods of splicing larger AL to CU. They have a "partition" that keeps the two dissimilar conductors from coming in contact.
To me that looks like tinned, or AL clad, copper, not aluminum.
jweinberg's Avatar
Thanks Jeff....
Why can't a split bolt connector be used if properly rated for this connection? I've seen them rated for Aluminum to Copper connections:
Split bolt connector with spacer bar Copper alloy-bodied, electro-tin plated For aluminum-to-aluminum cable Copper-to-aluminum cable Copper-to-copper cable Size= Min/Max range of equal main & tap Color: WIRE:Solid/Stra Size: SIZE:6/ 1/0
http://acmehardware.com/Electrical/M...ment-ASB1and0/
What would you consider to be a proper splice (Copalum Crimp?).
Old 11/4/06, 5:07 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with Speedy on this----that wire is not likely aluminum----note the cloth covering?
Old 11/4/06, 5:56 PM
Paul W. Abernathy's Avatar
Howdy,
Mind if I chime In.......
Actually older style split bolts that are copper where not designed to be CU/AL conection choices......The bridge in the middle was still copper and not voiding the copper to aluminum issue.....The ones that Speedy and I used today will be listed and labeled as AL/CU if they have that intent...and are usually silver in color ( well the ones I use are...lol...)
Many of the older split bolts that are copper colored did not allow for the mixing.......HOWEVER.....
With that said.......I do not think you should call this out because you are not able to verify the type of split bolt and the electrician is not going to come and cut off the tape to see....so it depends on the installation....
If it was a relative new change over.....we have to assume they used a AL/CU rated Split Bolt.......but being it is wrapped.....no signs of melting tape....due to possible signs of heat build up.....a condition that may occure in a situation where disimilar metals happen and resistance could lead to heat built up......sooooooo
so regardless of Alum or Copper Conductors.......since you can't see the end of the conductor to verify if it is Copper Tinned and so on......not enough of something I would call out....sorry...only my opinon.
Never said I was a GURU.......just opinionated.
lKnob & tube: 1880’s – 1930’s
lAC (armored cables) 1930’s - current
lNM (non-metallic) cloth covered:1928 – 1960’s
lNM (romex) (plastic sheathed): 1960’s - current
Copper conductors: 1880’s to current
Tinned Copper conductors: 1910’s to 1950’s
Aluminum conductors: 1960’s to current
Paul W. Abernathy,CMI,CPI,CME
Old 11/4/06, 6:56 PM
jweinberg's Avatar
I agree Paul. Mainly becuase it is not VISIBLE.
I did not call this out but did call out the oversized breaker (50 Amp on a 10AWG copper conductor) and the scorched wire and melted insulation in other parts of the panel, while calling for a complete evaluation of the panel by a licensed electrician.
The Sparky should decide if there is a problem with the splice while he is doing his complete evaluation.
Thanks to everyone that chimed in....
Jeff
Old 11/5/06, 12:14 PM
Good point. I rarely see that type and forgot that they exist.
Looking again at the photo, I agree.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/7/06, 9:04 PM
jweinberg's Avatar
Thanks guys....
Since you can't see the tips of the conductor, what clues are there that the wire is tinned copper and not aluminum?
Old 11/7/06, 9:10 PM
The cloth cover is one indicator - there are also knicks on the wire that have exposed the copper.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/7/06, 10:59 PM
Unmoderated Guest
For me it just an experienced eye. Old tinned CU looks quite different that solid AL.
Also as Jeff said, the braided/rubber insulation is quite common to tinned CU.
Old 11/7/06, 11:22 PM
as well it appears to be nicks that has the copper showing through... unless the color is just a bad image.
Thanks Nick I just hate it when I'm wrong cbottger Miscellaneous Discussion for Inspectors 0 6/9/07 3:01 PM
Messy work, but is it wrong? mtimpani Electrical Inspections 8 9/9/06 10:56 PM
What's Wrong Here? jtedesco1 Inspecting HVAC Systems 20 6/29/06 7:50 PM
