On a recent inspection, I had a 100 amp meter. SEC appears to be rated for 100 amps.
The Service Panel is a GE spit bus panel. The upper portion has several breakers (max 60 amp) controlling a sub panel & another either the AC unit or stove (I forget which). The breaker controlling the lower part of the panel is a double pole 60 amp breaker. So here is my question, Would you call this a 60 amp service or a 100 amp service for reporting purposes? I called it a 100 amp but am not for sure that I was correct. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Hi Mark,
as there is no "main" you need to go with the lowest rated of the other components, if the SEC is 100amp and the panel is 100 amp then I would probably call it as 100 amp unless it had a very old round meter base. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I sure do appreciate it! Mark Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I go a few step further in my reports, especially on older homes.
For example: - I note the meter base [200A] - I note the SEC [2/0 copper, 200A] - and the panels main disconnect rating [150A] Peter Doane Realty Check Inspection Service NACHI ID# 05120681
| Let's talk NUPI... | jbowman | General Inspection Discussion | 259 | 4/11/08 12:13 PM |
