Old 2/10/12, 11:24 AM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is offline
Default Appliances connected to GFCI
Both of these situations are a first for me (haven't seen this in 9 years).
The propane gas stove in the kitchen is wired to (connected to) the GFCI electrical receptacles in the kitchen.
The garage door opener (in the same house) is wired to (connected to) the GFCI electrical receptacles in the garage.
If these GFCI's trip, no cooking and no automated garage door opener.
Has anyone seen either of these conditions before.
I noted both in the report, but of course this is a bank owned property (which was actually in very good condition).
By the way the dishwasher was wired to a wall switch; if switch is off no power to the dishwasher.
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/10/12, 11:26 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: Appliances connected to GFCI
Everything that you've described is NEC compliant.
Old 2/10/12, 11:45 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
As long as GFCI can be located easily.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 11:47 AM
Jim Port Jim Port is offline
Unmoderated Guest
The switch for the DW is there to serve as a service disconnect in case someone is working on the unit. The NEC requires a means of disconnect and this is one option.
Under the latest NEC all receptacles in the garage need GFI protection including the ceiling mounted one.
The small appliance circuits are allowed to service the receptacle for a gas stove.
Old 2/10/12, 11:56 AM
KEVIN WOOD's Avatar
Yes but the reset should not be on the ceiling only the outlet, according to common sense. I have seen GFCI protection at the source for garage door openers on the 12 foot high garage ceiling.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 12:03 PM
That is no longer permitted under the 2011 NEC since they need to be readily accessible for testing purposes.
Old 2/10/12, 12:49 PM
KEVIN WOOD's Avatar
Nice to here that change in the NEC.
Also the application of GFCI is not needed on freezer or fridge,
another common sense area.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 1:00 PM
Joseph M. Whitt Joseph M. Whitt is offline
If it is in the garage or basement they are required to be GFCI protected and this is a good common sense move.
Mike Whitt
Contractor/Instructor
Old 2/10/12, 1:09 PM
Roy D. Cooke, Sr's Avatar
Stand by for ( unless things change ) there could be many changes to the Ontario electric Code example a Car charging unit in all Garages two car garage two charging units .
Now this I think is not a good idea if only 10% of the cars went electric we will have huge problems .
Not enough power to run the system .
Old 2/10/12, 1:31 PM
Unmoderated Guest
Kevin, I see you are under the CEC, but the NEC has removed the exemptions for GFI protection for appliances in garages.
Old 2/10/12, 1:50 PM
KEVIN WOOD's Avatar
Remember whether it is removed or not we only are concerned about what is in place at the time of the Home we are inspecting. Thus the common sense comment applies.
Look at comment #4
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 2:21 PM
Unmoderated Guest
Kevin, the way I took your comment was it is good to see that the GFI protection is not required as if there was an issue with having the GFI protection.
A properly operating appliance should not be tripping a GFI, whether it is required or not.
Old 2/10/12, 2:38 PM
KEVIN WOOD's Avatar
Very true and you are right. Problem is it can be shut off by anyone and then your Freezer goes off or Fridge. Even if there is a problem with the GFCI there is no guarantee that people will now it is supplying power to the Freezer or Fridge or that it has tripped.
Even a HI can trip the GFCI and be responsible for all the freezer meat. If it is required for Freezers or the Fridge I would question this with AHJ.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 2:55 PM
KEVIN WOOD's Avatar
Has there been anyone killed by Freezer?
Has there been any fires by Freezer or fridge not on GFCI?
What is the statistics for those that have lost food because of GFCI plugged into Freezer or Fridge.
They should also have small warning beeps installed when not functioning properly just like a smoke detectors.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/10/12, 3:36 PM
Unmoderated Guest
The codes are not about the safety of a freezer of meat or a fridge worth of leftovers. It is about life safety. I don't know the statistics about the fires, shocks etc.
There are GFIs with power loss alarms built-in.
Two appliances connected into single vent mpulka Inspecting HVAC Systems 8 2/17/10 6:18 AM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
