Old 6/30/08, 1:53 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Arc fault breakers
Hello there. This house has 3 traditional AFCI breakers for the bedrooms, only one bedroom tripped using the suretest, but that is a separate concern. What raised my curiosity is the additional breakers (pictures) labeled "arc fault". Haven't seen this before.
Old 6/30/08, 2:01 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Arc fault breakers
Those are not arc fault breakers.
What Code cycle was in force when the house was built?
Old 6/30/08, 2:04 PM
Nec 2005
Old 6/30/08, 2:46 PM
Jeffrey R. Pope's Avatar
I would have tripped all of the AFCI's and tested the bedroom outlets, to ensure they were not powered.
It may be that the AFCI's were not installed on the correct circuits.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/30/08, 2:51 PM
I did do that, power was only off in the master and one out of 3 guest bedrooms. Here is a pic of the traditional breakers. My guess is that the breakers labeled "arc fault" are supplying the other bedrooms. For some reason I did not trip those. Would it be reasonable to call the owner (1 year warranty inspection) and walk him through it?
Old 6/30/08, 2:56 PM
On a side note Jeff, is mentioning that afci protection was not confirmed using testing devices sufficient for our scope? The builder is aware and will (hopefully) remedy. I understand going through the motions to completely understand the defect, but in all honesty have I done enough by calling attention to a safety hazard?
Old 6/30/08, 2:59 PM
Bruce A. King's Avatar
No need to do that, just write up improperly labeled breakers and the other arc fault issues you found and let the builders electrician make all necessary corrections.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 6/30/08, 3:21 PM
No need to have the client tripping breakers. As Bruce said, just make the notes of your findings and move on.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/30/08, 3:40 PM
Doug Edwards's Avatar
Recently did a home where several of the "pigtails" on the AFCI were not connected inside the panel and another home where an AFCI labeled for one of the bedrooms was actually powering the kitchen. All signed off the local AHJ as good to go.
Old 6/30/08, 10:48 PM
ok.....so beyond the labeling issue for the panel which needs to be sorted out. Next time, press the AFCI trip buttons and THEN go and check the bedrooms fully.......then if receptacles or lights in the bedrooms function make reference to this and include in your report.....thats a better test than using the suretest....
Paul W. Abernathy
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
ARC Fault Breakers pmagrone Electrical Inspections 8 6/27/07 9:39 PM
Arc Fault Breakers pdoane Electrical Inspections 21 6/24/07 9:08 PM
