Michael LaCroix is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do arc fault circuit interrupter cause interferance with electronic equipment?
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is also worth noting that under the current NEC newly constructed homes will be required too have arc fault protection at all outlets that are within 60" of the floor and that are not required to be GFCI protected Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Where are you getting this information? This is not in the NEC.
I think that is just a very poor paraphrase of the 210 requirements. It also does not follow the NEC definition of outlets. Using the 5' distance no ceiling lighting or smokes would need to be AFCI protected.
As of January 2008 only "combination type" AFCIs will meet the NEC requirement. The 2008 NEC requires the installation of combination-type AFCIs in all 15 and 20 ampere residential circuits with the exception of laundries, kitchens, bathrooms, garages and unfinished basements.
Your are correct a poor paraphrase. I should have said outlets that are 60" above the floor need not be a combination AFCI (tamper proof), but are still required too be AFCI protected
Tamper proof receptacles have a shutter mechanism to prevent items like keys or pins from being inserted into the device and preventing shocks. Tamper proof has nothing to do with AFCI protection and can be used on regular circuits without AFCI protection.
It would also help if you would review the NEC definition of outlet and receptacle. They are not interchangeable. |
The word (grounding) should be replaced with grounded. Quote:
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Can an AFCI offer GFCI protection | gbeaumont | Electrical Inspections | 19 | 7/6/06 11:45 PM |
| Harmonized Ground Fault Circuit Interrupters | jtedesco1 | Electrical Inspections | 5 | 3/21/06 8:48 AM |
