Old 2/28/07, 3:18 PM
rcantrell rcantrell is offline
Default arching switches
On tues inspection I walked in the living room turned on the lights and noticed one that delayed coming on. Switched them on a couple of times and while doing this I heard an arching sound in the switch. Then smelled burning. Went to other switch that controls same of lights and it done same thing. The lights were five in a ceiling fan and one bulb was a flouresant bulb. It was the one that had a delay. Now I wrote it up but now just trying to figure out why arching. Thought maybe loose wire but not on both switches. Any ideas. The home is 8ys old.
Old 2/28/07, 3:58 PM
Default Re: arching switches
cheap switches?
Old 2/28/07, 4:54 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
This happened in my basement. You will probably find that the sound is coming from a loose wiring connection, probably connecting the fan/lamp i.e. not the switches.
But as a first check, make sure the bulbs are screwed in properly. A loose bulb will also make this sound.
It can be hard to tell where the tzzz is coming from.
I removed my lamp for inspection and the hot wire just fell off the terminal. Could have been a fire waiting to happen.
Arching Causes Main Breaker To Trip? msylvester Electrical Inspections 10 10/22/07 4:57 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Life Expectancy of Equipment, switches, receptacles pbennett1 Electrical Inspections 16 2/19/07 1:33 PM
Lights & switches dmacy Electrical Inspections 21 1/27/07 2:15 PM
3 way switches cfuoco Electrical Inspections 4 2/1/06 9:00 PM
