Old 3/15/08, 11:15 AM
Peter Hughes Peter Hughes is offline
Default Attic lights
Any information on the rules related to the installation of an attic light would be appreciated.
I.E.
Fire Codes
Location
Wattage
Switch
area served (sq feet)
NEC / IRC (other than IRC E3803.4)
Etc.
"Arrogance and Ignorance are not mutually exclusive"
Old 3/15/08, 11:31 AM
Marc D. Shunk's Avatar
Banned
Default Re: Attic lights
The only requirements are that if that attic is used for storage or the has equipment installed in it that needs servicing, a switch controlled light needs installed at or near the normal entrance. This could be a wall switch or a pull string on the fixture. If there will be employees of a company working on the A/C, the minimum lighting levels are 10 footcandles.
Old 3/15/08, 12:29 PM
Thank you Marc for reply
Truss Uplift rcooke Canadian Inspectors 5 2/26/08 7:43 PM
Attic Temps mroe Miscellaneous Discussion for Inspectors 12 8/26/07 9:32 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 7:29 PM
Attic Inspection rbritton Electrical Inspections 19 8/2/06 2:58 PM
