To be performed only when contracted to do so and with proper insurance and training.
Generating a home- Guidelines and Procedures 1.) Verify that the power company has disconnected service to the home. 2.) Turn off the main breaker. If the home does not have a main breaker double check to make sure the power company has killed all power to the home. 3.) Turn off all appliances, switches and make sure the heating and air thermostats are in the OFF position. 4.) Plug power cord into the best accessible 220 outlet using the proper power cord. 5.) Turn on generator and let the generator warm up for a couple minutes. 6.) Plug power cord into generator. You are now ready to perform your system checks. Shutting down procedures 1.) Unplug power cord from generator. 2.) Wait a couple of minutes to allow generator to run without a load, then shut generator off. 3.) Unplug from homes 220 outlet. Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 Last edited by fmagdefrau; 8/26/10 at 5:55 PM.. |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I seriously hope that you are not advocating the use of a suicide cord to backfeed power into a receptacle.
Did I?
Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
Using the below example would require a male to male extension cord which would be the suicide cord... Quote:
Seasoned inspectors should not be advocating this practice regardless of the method(s) used.
As an "employee" or independent-contractor working for a firm, you may be authorized to do this as part of your inspection, in which case you would probably be provided with appropriate insurance coverage. As an independent home inspector (you may want to check with your carrier) it is very unlikely that your GL or E&O will cover you for problems associated with this practice. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
How would you re-write this step?
I added a warning at the top, thank you.
There is no way, It is not worth it. Seller wants to sell the home turn the power on. or the buyer accepts the power not being on. This could get someone killed. Banks are trying to get away from any responsibility . If you want the liability's go for it, I will wait to read all about it.
Interesting this would come up right now as I was contacted by a company looking for inspectors to do just this and more. Inspector would need a generator and air compressor (have to provide photos of both to them prior to hiring you). They said the dryer outlet would be the point of connection. Compressor is to check plumbing. Out of curiosity I went ahead and told them to send me the package for review. After reading through it I will amazed if they find anyone willing to do everything they want for the incredibly small fees offered. It included all kinds of other tasks, duties and responsibilities. I haven't written back yet telling them not NO but hell NO. Does this have anything to inspecting HUD properties?
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 8/26/10 at 6:04 PM.. |
Nor should it be used when your power goes out. Only to be performed when the local power company has killed the power and capped the lugs at the meter. Also when you have been contracted to perform this type of system check with proper training and insurance. Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
Just maybe they will see this first. Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
Gotcha. I am not sure I would want to roll into some of our HUD housing areas with my new generator, compressor, laptop ,etc....oh yeah don't forget the new AR15s needed with a couple of bubbas to watch everything while you "hook it up" for $45. While you are there, mow the grass and fix anything that needs fixing.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I know Frank . But i do think it is a bad idea really. I used to run the Gen sets for the company i worked for. I feel if these are Bank homes the can afford to turn on the utilities . As Doug said they probally not going to pay for the extra cost involved. and the liability's are great. If you feel comfortable and trained well go for it. Also as Jeff mentioned i would check my insurance also. The problem i see is the New guy thinking this will add Business and wind up killing someone.
In some of our "hoods" you can get shot for a six pack, an egg salad sandwich and the change in your cupholder.
| Washington Home Inspections | sstanczyk | Miscellaneous Discussion for Inspectors | 8 | 9/2/06 2:53 AM |
