If a homeowner wishes to install a thermostat on the wall, is it acceptable and safe to run a single 12/2 wire to a single pole, 2 wire thermostat? One side of the 240 supply would go from a junction box in the crawlspace direct to the heater while the other side goes from the junction box up to the thermostat on one leg of the 2/12, back on the other leg to the junction box? This seems OK to me, but would like confirmation or ......
sounds ok to me as well. It's just acting as a diconnect.
Bill Corbett C.H.I. Magic City Inspections LLC InspectingtheUnexpected.com
In this case the thermostat is NOT ascting as the disconnect since it is only breaking one hot leg of the 240v circuit.
In a one family dwelling the main breaker is considered the "other means" of disconnect for fixed electric heat. |
That is a controller function, not a disconnecting function.
| Client wants a new water heater | adirienzo | General Inspection Discussion | 47 | 7/14/10 2:03 PM |
| Hot Water Heater Question | mpeterson | Plumbing Inspections | 8 | 3/31/07 1:59 PM |
| Tankless Water Heater Question | kweiss | Plumbing Inspections | 1 | 3/8/07 9:57 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
| Question on Fresh air ducting | rcross | Inspecting HVAC Systems | 10 | 1/25/06 1:25 PM |
