Old 1/2/06, 9:19 AM
Default Basic Electrical Theory Questions- EASY
1 What is the name for the flow of electrons in an electric circuit?
  • A. Voltage
  • B. Resistance
  • C. Capacitance
  • D. Current
2 What is the basic unit of electric current?
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
3 Which instrument would you use to measure electric current?
  • A. An ohmmeter
  • B. A wavemeter
  • C. A voltmeter
  • D. An ammeter
4 What is the name of the pressure that forces electrons to flow through a circuit?
  • A. Magnetomotive force, or inductance
  • B. Electromotive force, or voltage
  • C. Farad force, or capacitance
  • D. Thermal force, or heat
5 What is the basic unit of electromotive force (EMF)?
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
6 How much voltage does an automobile battery usually supply?
  • A. About 12 volts
  • B. About 30 volts
  • C. About 120 volts
  • D. About 240 volts
7 How much voltage does a wall outlet usually supply (in the US)?
  • A. About 12 volts
  • B. About 30 volts
  • D. About 480 volts
8 Which instrument would you use to measure electric potential or electromotive force?
  • A. An ammeter
  • B. A voltmeter
  • C. A wavemeter
  • D. An ohmmeter
9 What limits the current that flows through a circuit for a particular applied DC voltage?
  • A. Reliance
  • B. Reactance
  • C. Saturation
  • D. Resistance
10 What is the basic unit of resistance?
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
11 Which instrument would you use to measure resistance?
  • A. An ammeter
  • B. A voltmeter
  • C. An ohmmeter
  • D. A wavemeter
12 What are three good electrical conductors?
  • A. Copper, gold, mica
  • B. Gold, silver, wood
  • C. Gold, silver, aluminum
  • D. Copper, aluminum, paper
13 What are four good electrical insulators?
  • A. Glass, air, plastic, porcelain
  • B. Glass, wood, copper, porcelain
  • C. Paper, glass, air, aluminum
  • D. Plastic, rubber, wood, carbon
14 What does an electrical insulator do?
  • A. It lets electricity flow through it in one direction
  • B. It does not let electricity flow through it
  • C. It lets electricity flow through it when light shines on it
  • D. It lets electricity flow through it
So.....How did you do no these BASIC electrical theory questions?
Paul W. Abernathy
Old 1/2/06, 9:26 AM
Default Re: Basic Electrical Theory Questions- EASY
Before you scroll down and cheat......Really take the quiz......lol
Answers to questions
  • A. Voltage
  • B. Resistance
  • C. Capacitance
  • D. Current
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
  • A. An ohmmeter
  • B. A wavemeter
  • C. A voltmeter
  • D. An ammeter
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
  • A. About 12 volts
  • B. About 30 volts
  • A. About 12 volts
  • B. About 30 volts
  • A. An ammeter
  • B. A voltmeter
  • C. A wavemeter
  • D. An ohmmeter
  • A. Reliance
  • B. Reactance
  • C. Saturation
  • D. Resistance
  • A. The volt
  • B. The watt
  • C. The ampere
  • D. The ohm
  • A. An ammeter
  • B. A voltmeter
  • C. An ohmmeter
  • D. A wavemeter
Paul W. Abernathy
Old 1/2/06, 10:03 AM
Kevin P. Williams's Avatar
Kevin P. Williams Kevin P. Williams is offline
HEY, I got them all correct
good little test, thanks Paul
Old 1/2/06, 10:05 AM
lol...yep just to bring everyone back to electrical theory basics...lol
Paul W. Abernathy
Old 1/2/06, 10:07 AM
jferry's Avatar
jferry jferry is offline
Got 7, 12 and 13 wrong.
Joseph A. Ferry, Esquire
Two Penn Center Plaza
Suite 200
Philadelphia, PA 19102
215-854-6444 tel.
215-243-8202 fax
gbeaumont's Avatar
Thumbs up Re: Basic Electrical Theory Questions- EASY
Hi Paul,
Good one, I can't believe I got question 1 wrong, I shouldn't do tests until the morning coffee has kicked in
when do we get the next installment of hard questions?
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 1/2/06, 10:11 AM
I would lOVE to do a weekly quiz installment.......of basic electrical and electrical training questions....you give the word and I will do a weekly, daily or so on program for it.
I just cant get enough electrical stuff...lol
Paul W. Abernathy
Old 1/2/06, 10:13 AM
You know Joe........those are the 3 that would KILL you in the field...tehehhe....Don't worry I got the same ones wrong on the Lawyer Bar Exam as well...thehehehe....the exact same numbers...
Paul W. Abernathy
Old 1/2/06, 10:21 AM
jferry's Avatar
I've been killed a number of times at the roulette wheel by those same numbers.
Suite 200
215-854-6444 tel.
215-243-8202 fax
Old 1/2/06, 10:23 AM
lol...Now that frightens me joe....a lawyer that Gambles...lol.....hahhahah
Paul W. Abernathy
Old 1/2/06, 10:27 AM
Old 1/2/06, 10:39 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
I Oopsed on #13... I didn't read the whole answer.
Scores
14 of 14 100%
13 of 14 93%
12 of 14 86%
11 of 14 79%
10 of 14 71% If 75% or better was required to pass this or less would be failing. More studying would be in required.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/2/06, 1:42 PM
I breezed right through that thing...then I saw the answers!!
Oh, well...
Actually, I only got two wrong--one was #7 and I don't know why.
I remember in college on the final exam for one course in music I missed one
question--I answered 5/8 time as symetric. Well none of us are perfect.
always read and re-read the question and don't get in a hurry--the bus will wait for you.
Well, not all the time, anyway.
Good quiz, though. Let's do another real soon.
Old 1/2/06, 2:03 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Great post Paul.
Please keep them coming.
Old 1/2/06, 7:59 PM
lagudo lagudo is offline
Please Note: lagudo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why not make this a course like the online Roofing Course that we have on our site now and upon completion we can get the hours needed for continuing education. Just a thought.
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Free! NACHI Chapter Electrical Inspection Seminars jtedesco1 Inspection Education & Training 0 10/2/06 4:40 PM
Some good questions that always need answers jtedesco1 Electrical Inspections 5 6/16/06 9:10 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
