Old 2/27/08, 1:55 PM
tlower's Avatar
tlower tlower is offline
Default Beautiful
An inspection I did earlier today (Nice Panel). I don't get to see many of these around here much.
beautiful-p2270015.jpg   beautiful-p2270017.jpg   beautiful-p2270018.jpg   beautiful-p2270019.jpg   beautiful-p2270020.jpg
Timothy Lower
Centerville, Ohio
Old 2/27/08, 1:59 PM
Bob Elliott's Avatar
Default Re: Beautiful
Are those paper tags on the conductors?
Old 2/27/08, 2:09 PM
tlower's Avatar
No that is extra casing cut off the wire
Timothy Lower
Centerville, Ohio
Old 2/27/08, 2:20 PM
So they must have had a feeder conductor as the casing is thicker than the breaker conductors.
Never seen that.
What is the breaker upper right side with a yellow outline?
Does look neat.I am guess 200 amps since I cant read the main.
Old 2/27/08, 2:39 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Never seen that.
Quite common here. Looks good.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/27/08, 3:23 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Never seen that.
that yellow outline around the breaker that is a lockout tab so if somone working on something on that circuit they can use the padlock to lock it out or some case lock it on so someone don't turn off the critcal circuit like computer or burgular alarm.
it more common to see that in commercal location so that way it work two way one for safety reguation or used to lock on something that someone dont turn off actidentally.
Merci, Marc
Old 2/27/08, 4:05 PM
Charley L. Bottger's Avatar
Not as pretty as this one was just bragging on it yesterday. This was the neatest wire job I have ever observed bar none
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/27/08, 4:20 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Both very nice. Better than the bird nests we usually get to look at.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/27/08, 6:10 PM
tlower's Avatar
[quote=relliott]
quote]
Mark is correct. It acts as a lockout. I blew it up for you to see it a little better.
Timothy Lower
Centerville, Ohio
Old 2/27/08, 10:21 PM
Never seen that.
It's just skins off the Romex. We do it as we wire up the house, then when we make up the panel its a cinch to fill out the directory accurately.
Old 2/27/08, 10:24 PM
Thanks for the answers,
I have seen the lockouts before
The Romex is rare around here.
Nice idea.
Old 2/27/08, 10:35 PM
Now I see why you haven't seen this being in the Chicago area.
Beautiful Holiday Scenes belliott Miscellaneous Discussion for Inspectors 17 12/26/07 8:41 AM
CT NACHI mails out beautiful post cards. gromicko Miscellaneous Discussion for Inspectors 0 1/4/06 12:45 AM
