Old 11/18/09, 6:09 PM
rbero rbero is offline
Send a message via Yahoo to rbero
Default Bedroom w/o grounded outlets
My daugther has a rental where the tennets are looking for some sort of aid for paying rent and the agency that handles that does a inspection of the house. The house was about 90% rewired one of the bedrooms has 2 outlets that are 3 prong but the ground is not there,i checked the the service panel and found the bedroom has the old two wire system to the breakers. What would be the easyist way to correct this problem?
Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America)
Old 11/18/09, 6:11 PM
mnahrgang's Avatar
Default Re: Bedroom w/o grounded outlets
Replace the three prong with two prong receptacles.
Mark Nahrgang
www.HeyMark.info
Old 11/18/09, 6:12 PM
That was my thought also
Old 11/18/09, 6:14 PM
Marcel Gratton's Avatar
Fill the receptacle ground with epoxy.
On The Level Inspection
Gatineau, Québec
Old 11/18/09, 6:16 PM
The easiest thing (2 prong receptacles are harder to find and expensive.) may be to put a GFCI on the first receptacle on the circuit and label the others "no equipment ground".
Larry Kage, CMI
231 929 3525
Old 11/18/09, 6:18 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Agree, the two prongs are very hard to find.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 11/18/09, 8:40 PM
thanks guys i found some 2 pronged outlets at home depot for 1.48 i will install them in the morning
Old 11/18/09, 9:23 PM
Paul W. Abernathy's Avatar
Why do people think (2) prong plugs are hard to find. I see them all the time in Home Depot, Lowes and most normal hardware stores. Anyway, if it was MY daughters dwelling or apartment then I would simply meet the code section below which is designed to be a practical safeguard and install the GFCI and label the downstream receptacles as "No Equipment Ground" and "GFCI Protected".
(3) Non–Grounding-Type Receptacles.
Where attachment
to an equipment grounding conductor does not exist
in the receptacle enclosure, the installation shall comply
with (D)(3)(a), (D)(3)(b), or (D)(3)(c).
(a) A non–grounding-type receptacle(s) shall be permitted
to be replaced with another non–grounding-type receptacle(s).
(b) A non–grounding-type receptacle(s) shall be permitted
to be replaced with a ground-fault circuit interrupter type
of receptacle(s). These receptacles shall be marked
"No Equipment Ground." An equipment grounding conductor
shall not be connected from the ground-fault circuit interrupter-
type receptacle to any outlet supplied from the
ground-fault circuit-interrupter receptacle.
(c) A non–grounding-type receptacle(s) shall be permitted
to be replaced with a grounding-type receptacle(s)
where supplied through a ground-fault circuit interrupter.
Grounding-type receptacles supplied through the ground fault
circuit interrupter shall be marked "GFCI Protected"
and "No Equipment Ground." An equipment grounding
conductor shall not be connected between the grounding type
receptacles.
Paul W. Abernathy,CMI,CPI,CME
Old 11/18/09, 9:35 PM
D'oh! I tried to help a friend find some not long ago and did the searching online. Next time I'll actually go into a store
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 11/18/09, 9:38 PM
lol......man those big box stores have everything today....
Old 11/19/09, 1:06 AM
David A. Andersen's Avatar
If all else fails, go to a wholesaler.
They do sell to the public.
BPI# 5015804
Old 1/9/10, 11:58 AM
nbhi's Avatar
nbhi nbhi is offline
Paul
By just adding a GFCI outlet with no equipment ground, isn't that still a false sense of security? I have run into situations in kitchen areas where GFCI'S are present without a equipment ground and the outlet will not trip properly, please advise.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 1/9/10, 12:01 PM
Michael Larson's Avatar
Originally Posted by nbhi View Post
Paul
If yo uare trying to test a GFCI that is not connected to ground with a 3 light tester, it wont work.
Use the test button on the outlet.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/10, 12:25 PM
nbhi's Avatar
I am using my sure tester that simulates a load that should trip, but they never do. I would think in order to function properly, a equipment ground needs to be installed.
Old 1/9/10, 12:39 PM
ecolclasure ecolclasure is offline
Just because your tester doesn't trip doesn't mean that the outlet is bad, all it means is your test failed. Your tester won't work in this situation because you are trying to ground fault the outlet to the ground in the box that does not exist. If you were to actually ground fault to ground it would trip. use the button.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Where is it written.... bgromicko General Inspection Discussion 18 1/19/08 10:02 PM
opinions on GFCI outlets for non grounded oputlets jmerritt1 Electrical Inspections 23 5/11/06 8:22 PM
