Old 11/1/08, 2:24 PM
nbhi's Avatar
nbhi nbhi is offline
Default Where to begin?
Here are a few pics. from todays inspection. There is a knife disconnect to the right taht shuts the system down. My concern is that, the sub panels are all coming from the panel on the right with the knife disconnect. I could not locate where the knife panel was bonded. All comments are welcomed.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 11/1/08, 2:37 PM
Default Re: Where to begin?
Begin by referring it to a licensed electrician. It has so many "add-ons" that are improperly installed that this thing could be a hazard.
Old 11/1/08, 2:42 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Some of those wires coming off the main are horribly undersized. (100(?) amp to 12 guage)!!
Old 11/1/08, 8:00 PM
rromoser's Avatar
rromoser rromoser is offline
Recommend having an automatic fire suppression system installed...
Old 11/1/08, 8:04 PM
rromoser's Avatar
Recommend installing a 100 amp circuit breaker panel minimum. Eliminating all of the little sub-panels. Appears that those are 100 amp cartridge fuses in the main disconnect.
Old 11/2/08, 12:53 PM
Let's assume they do your recommendation and complain later because it is inadequate. Where do you stand?
On what basis do you make that recommendation?
Larry Kage, CMI
231 929 3525
Old 11/3/08, 4:29 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Simple .,,
Get the electrician come out and get this mess fix up too many code volitations there { I am not going to list all of it }
Merci,Marc
PRO-LAB to begin marketing InterNACHI/NACHI.TV pay-per-view courses. gromicko Thermal Imaging, Infrared Cameras & Energy Audits 1 6/20/08 3:18 PM
After today..I may begin to do things differently tneumann Plumbing Inspections 11 3/10/07 6:26 PM
