Something different alright.
Posted on Mike Holt’s news letter.
http://www.biceptacle.com/public/assets/images/hp-feature-150x245.jpg
Mike’s newletter members get a discount to buy them.
Thanks Mike.
Thanks Mike.
That’s cool I have a power strip that is like that.
Sure would make furniture arranging easier with table lamps.
Great idea though it needs a larger box and will not fit in as a replacement for a standard single outlet I imagine .
You got that right Jim.
Gives you a duplex switched or a duplex hot. Or one of each.
They fit in the same box Bob.
http://www.earthtechling.com/2012/03/next-gen-outlet-helps-you-plug-into-energy-savings/
There are pretty cool and probably best suited for new construction.
Not an easy upgrade on a slab foundation and on the exterior wall, raised foundation different story. Since each outlet requires constant hot sockets like a typical outlet it would also need a switched hot. Depending on outlet to switch location it can be quite a task
An easy work around
Get the Clapper
Clap – On
Clap - Off
Then right on.
I like the new outlets with the USB receptacles for charging devices http://gizmodo.com/5418898/10-usb-power-outlets-sound-like-a-no+brainer.
They will definitely go into the house I am remolding.
stock in xanax is a good bet once these catch on
wire mokeys that p up a rope whenever the ground up/down debate starts will be melting down like Ding Dong from Oz
