Need a quick answer. I don't suspect Chinese drywall. Is there another reason for copper to be black like this?
Can't seem to figure out how to put a picture from my phone in. On some of the neutrals it looked almost crusted on. Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Check copper pipes and HVAC compnents Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
The copper pipes looked ok. That's why I don't think it would be the drywall.
Heres a couple of pictures.
Chorine ,cat pee, Horse Pee and or other chemicals could be the reason . Roycooke@hotmail.com I prefer E-mail Roy Cooke UE mlarson is on my ignore list "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
Second floor condo. The panel is about eight feet from the laundry. Rh was 35%. I even ran the washer through a full load to re check RH. only went up 3%. I'm stummped.
They say do not store laundry supplies near your furnace for that reason Roycooke@hotmail.com I prefer E-mail Roy Cooke UE mlarson is on my ignore list "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
Could be
I would suspect the chlorine in the air from the laundry. This is a form of oxidation and I have seen this exact condition on wire terminations many times where chlorine and moisture are both present.
Best to recommend service by a licensed electrical contractor. Normally it is a process of cleaning the strands with a wire brush, applying an anti oxidant compound, and properly torquing the connection. The source of moisture may be the dryer instead of the washer. I would suspect ventilation/air flow might not be adequate in the area where the panel and laundry is located. |
I inspected a home a few years back that had the pool equipement along with its chemical (chlorine) stored in basement, basement had a walk-out to the pool, and the electrical panels were located in that same room.
Copper wiring were not discoloured but cabinets were rusted. Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
On a side bar, I have also repaired the same oxidized wire terminations in electrical cabinets that control industrial plastic extrusion processes. RH is typically very high and this is very common in processing systems for PVC products. I guess there are so many possible variables in the world that it is difficult to speak in terms of absolutes or certainties. |
I wrote it up as follows:
It appears that the copper wiring in the service panel has oxidized. The exact reason is unknown as there are many variables as to why this can happen. It is recommended that a licensed electrician evaluate and repair as required. Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
I agree, I've seen residual sulfer corrosion/damage/deterioration/staining like this multiple times. Was there any other blackened areas/components like Michael said?
| Panel wiring question | dmacy | Electrical Inspections | 12 | 2/2/09 8:38 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Main Panel wiring | sstanczyk | Electrical Inspections | 2 | 2/9/06 8:55 AM |
