Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
I inspected a condo this morning and about one third of the outlets had a black residue around them. I think when devices are plugged into the outlets there must be some arching?? What can be the cause of the residue and what's the fix? Thanks in advance for the answer.
Hi Skip,
Outlets like anything else don't improve with age, I suspect that the outlets are rather worn and don't grip well on the plug tangs, well used outlets over 20 years or so old tend to need replacement. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks for the input Gerry. This unit is nine years old. Could it also be poor workmanship and/or low quality outlets?
This may sound silly but do they burn a lot of candles in this house? How about air infiltration around the boxes/devices? I would guess it is NOT arcing. |
Looks like dirt to me too. I don't think it's arcing. . .
Skip, was this issue more apparent on the exterior walls? Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I saw the residue on interior and exterior wall outlets. Dirt around here is red. As in rock hard clay. It's not dirt. The palce was vacant. Can't tell if they burned candles. The residue is only around outlets. No residue on switch plates. And no residue on an receptale unless its around the outlet.
I should have sniffed the outlets. To see if they smelled like an electrical issue!!
Sometimes this is observed when electrical outlets are non-compliantly installed in stud bays that are being used for return air. A tiny bit of return air is being sucked through whatever switches and/or receptacles are installed in that stud bay. A home with negative pressure issued, due to a number of factors (including tight construction, in which exhaust fans are used in the kitchens and bath, or combustion air is taken from indoors, or an improperly function air to air heat exchanger), will observe a tiny amount of air infiltration through the devices mounted in the exterior walls, dragging in whatever pollution along the way.
I see this very commonly, and I wouldn't especially call it alarming from my point of view, unless the device fails to function. |
That stripe on the plate is a little puzzling. Did you do that when you swiped it with your finger, or was that there? Seeing that stripe, I'm starting to think "Glade Plug-In" or something along those lines. We have a couple around the house, and they seem to attract dust, for some reason.
Plug-in air freshener or nightlight
Don Peterson, CMI AmeriDream Home Inspections Inc. NYS License: 16000014560 |
That's where I swiped my finger. The residue was on outlets no where close to stud bays with returns. I saw this once a couple of months ago in another property. It was only on one outlet.
Now that I think of it, I could tell these people didn't clean much. The place was not kept well. Maybe it is dust that formed around plug-in air fresheners. I would hate to miss a major electrical issue on this one. I might call for an electricain anyway. Any thoughts?
Those plug in air fresheners produce more than enough heat to create warm air currents. This is your culprit.
| Red & Black | dbucknavich | Electrical Inspections | 9 | 3/4/07 8:35 AM |
| Black wires | dmacy | Electrical Inspections | 7 | 7/6/06 8:53 PM |
