Old 6/17/11, 9:34 AM
Jim Fleischmann Jim Fleischmann is offline
Default Blackened copper wire and pipes
Can someone give an explaination of the cause for copper wiring and water pipes to become discolored in a 50 year old home in southern Wisconsin.
Along with many other issues, this panel has no grounding conductor, just the grounded (neutral) conductor. The main service disconnect is at an exterior location. Blackened ground wires are also present in open junction boxes in other parts of the basement.
The stained/tarnished copper water pipes have a black soot-like film over them, but the black-iron pipe and steel conduit are absolutely clean.
There is a possibility of sewer gas entering the area from a nearby improper length laundry drain to a water trap.
This basement appears average for moisture content, with no other signs of chemicals, Chinese drywall, etc.
What's the explanation?
Jim Fleischmann
Eagle Eye LLC Home Inspections
608 751-6651
608 757-9299
blackened-copper-wire-and-pipes-img_4018.jpg   blackened-copper-wire-and-pipes-img_4017.jpg   blackened-copper-wire-and-pipes-img_4019.jpg   blackened-copper-wire-and-pipes-img_4021.jpg
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/17/11, 9:36 AM
Roy D. Cooke, Sr's Avatar
Default Re: Blackened copper wire and pipes
http://www.nachi.org/forum/f22/black...er-lines-2837/
Go here ... Roy
Old 6/17/11, 10:45 AM
David A. Andersen's Avatar
Are you on a well?
The pattern on the water lines indicate condensation.
Sulfur dioxide (or other chemicals in the air from outgassing) combines with water and corrodes copper materials.
BPI# 5015804
Old 6/17/11, 11:01 AM
It is a private well system.
Jim Fleischmann
608 751-6651
608 757-9299
Old 6/17/11, 11:21 AM
Chemicals stored in the area of the electric panels and plumbing can cause this condition.
If the condition is widespread throughout the house, I would look at the well water as the source (not necessarily the cause).
BPI# 5015804
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Grounding conductor to copper water pipes Ian Gills Electrical Inspections 2 11/27/07 5:25 PM
green pipes jmaisano Plumbing Inspections 11 11/6/06 11:59 PM
