I know this has been discussed here, but I'm not sure we've ever come to a concensus as to the issue that causes it.
The house has been vacant/unoccupied for nearly one year, built in 2005. All grounding conductors are black. Some show signs that they may have been heated with a blueish tint. Most of the ungrounded conductors (neutrals) were also black. None of the ungrounded conductors were black. Interior receptacles show no abnormal voltage-drop, and there was no discoloration at the conductors inside the home. The panel wiring showed no abnormal heat ranges with thermal imaging. What say you? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ever see a copper roof?
It's you left-coast-outdoor-panel guys.
This one is in the desert, 3200 sq ft for $289k. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Well water? Sulfer? Maybe an aeriator
I know that turns copper black. |
Read the replies: http://forums.mikeholt.com/showthread.php?t=93357
Jeff
The copper and the black has nothing to do with the fact that one is hot and one is at ground level Look at it this way if the breaker is closed both are at the same level Copper changes color based on what is in the air and on what is on the wire Why some of the "HOT" wires were not black I can not answer Something is not known I do not see a reportable issue without additional information I do not think that a good electician could help without additional information rlb |
Joe your post did not help
rlb |
Could the presence of excessive harmonics within the system attract airborne particles?
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
LOOK HERE TO search Last edited by jtedesco1; 4/19/08 at 8:51 AM.. |
We have no information to suggest there is a problem other than cosmetic.
I would still "observe and report" what is present and also report the fact that no factual information has been located that explains the darkened copper. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Hey all, my first post - I am new to the board and really appreciate the serious stuff, the code specific items and the funnies too!
Boaters here http://continuouswave.com/ubb/Forum6/HTML/001067.html seem to think the black copper is due to salt. Jeff |
| Netural & grounds tie together | ksitzes | Electrical Inspections | 8 | 1/13/08 5:38 AM |
| Neutrals and Grounds | ekartal6 | Electrical Inspections | 9 | 10/8/07 11:42 AM |
| Multiple grounds | gmathias | Electrical Inspections | 11 | 4/30/07 1:49 PM |
| Double tapped grounds. | gheller | Electrical Inspections | 10 | 4/17/07 8:14 PM |
| grounds and neutrals | nbhi | Electrical Inspections | 4 | 4/4/06 11:14 PM |
