Old 10/14/10, 9:35 AM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Bond at Panel
I recently did an inspection on a 2 family home. One electrical service line, 2 meters, 2 main panels. There is a ground connection and a bond between the neutral bar and the panel at one of the panels. The second panel did not have either. I believe a single ground connection is okay, but am wondering if this panel should be bonded. Any thoughts?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/14/10, 10:25 AM
Jeffrey R. Pope's Avatar
Default Re: Bond at Panel
Both panels (as service equipment) must be mechanically connected (bonded) to each other and to the grounding electrode.
The grounded (neutral) conductors at the service equipment must also be bonded to the GE.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/14/10, 10:48 AM
Thanks Jeff. I'm going with that.
774 Manor Road
718-514-3393
Old 10/15/10, 3:06 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Why do the two panels need to be mechanically connected to each other?
Old 10/15/10, 4:33 PM
Grouped disconnects on a single drop should be bonded, no?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/15/10, 4:49 PM
Yes, you're correct. In my mind I took mechanically connecting the two disconnects as requiring some sort of raceway connection between them. They could simply be bonded by having a bonding jumper from each disconnect to the GEC or some other bonding arrangement where there is no direct connection between the two.
Old 10/15/10, 5:11 PM
I was trying to help differentiate bonded (the mechanical "connection" between components) and grounded (the connection to earth).
Many inspectors have a difficult time with these terms.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/15/10, 5:46 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
John-
Was the house in Staten Island? BX throughout? Were the panels connected by conduit with bonding jumpers?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Does Anyone See A Panel Bond Here? pdickerson Electrical Inspections 14 10/24/07 11:40 AM
