this is a 125a sub. about 1' away from the main, for the finished basement. there is only one bus bar, it's bonded to the back of the panel, all the grnds and neutrals are here. shouldn't they be separated?
Yes.
250.24(A)(5) Load-Side Grounding Connections. A grounding connection shall not be made to any grounded circuit conductor on the load side of the service disconnecting means except as otherwise permitted in this article. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 3/5/06 at 1:40 AM.. |
| Bonded to building Steel Structure Frame | mcyr | Electrical Inspections | 11 | 4/29/09 12:50 PM |
| 35 year old metal roofing, bonded granules, panels molded like shakes | kshepard | Exterior Inspections | 8 | 9/20/07 5:14 PM |
| bonded? | cbuell | Electrical Inspections | 8 | 2/8/07 6:42 PM |
| Are these buses bonded? | jfunderburk | Electrical Inspections | 3 | 6/16/06 11:27 AM |
| Bonded to panel? | cobarr | Electrical Inspections | 8 | 4/14/06 1:09 AM |
