Old 3/4/06, 2:09 PM
Default What Is Bonding......
Hey Guys,
I was going over my lesson plans and found this image that explains bonding rather nice...in case anyone wanted to refresh their memory....this is an image from Mike Holt......Really does have the best images in the business.....
Mike's Comments: Why is grounding so difficult to understand? One reason is because many do not understand the definition of many important terms. So before we get too deep into this subject, let’s review a few important definitions contained in Articles 100 and 250.
Bonding [100]. The permanent joining of metal parts together to form an electrically conductive path that has the capacity to conduct safely any fault current likely to be imposed on it. See Image Above !
Mike's Comment: Bonding is accomplished by the use of conductors, metallic raceways, connectors, couplings, metallic-sheathed cables with fittings, and other devices recognized for this purpose [250.118].
Bonding Jumper [100]. A conductor properly sized in accordance with Article 250 that ensures electrical conductivity between metal parts of the electrical installation.
Effective Ground-Fault Current Path [250.2]. An intentionally constructed, permanent, low-impedance conductive path designed to carry fault current from the point of a ground fault on a wiring system to the electrical supply source.
The effective ground-fault current path is intended to help remove dangerous voltage from a ground fault by opening the circuit overcurrent protective device.
Equipment Grounding Conductor [100]. The low-impedance fault-current path used to bond metal parts of electrical equipment, raceways, and enclosures to the effective ground-fault-current path at service equipment or the source of a separately derived system.
Author’s Comments:
•The purpose of the equipment grounding (bonding) conductor is to provide the low-impedance fault-current path to the electrical supply source to facilitate the operation of circuit overcurrent protection devices in order to remove dangerous ground-fault voltage on conductive parts [250.4(A)(3)]. Fault current returns to the power supply (source), not the earth!
•According to 250.118, the equipment grounding (bonding) conductor must be one or a combination of the following: Figure 250–5
  • Wire Type. A bare or insulated conductor [250.118(1)]
  • Rigid Metal Conduit [250.118(2)]
  • Intermediate Metal Conduit [250.118(3)]
  • Electrical Metallic Tubing [250.118(4)]
  • Listed Flexible Metal Conduit as limited by 250.118(5)
  • Listed Liquidtight Flexible Metal Conduit as limited by 250.118(6)
  • Armor of Type AC cable [250.118(]
  • Armor of Type MC cable as limited by 250.118(10)
  • Metallic Cable Trays as limited by 250.118(11) and 392.7
  • Electrically continuous metal raceways listed for grounding [250.118(13)]
  • Surface Metal Raceways listed for grounding [250.118(14)]
Again courtesy of Mr. Holt.......
Paul W. Abernathy
Old 3/4/06, 2:40 PM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: What Is Bonding......
Wow, and all this time I thought you an d a best friend......
Thanks Paul !!!
Old 3/4/06, 2:59 PM
Justo..........I don't have friends...........
Paul W. Abernathy
Old 3/5/06, 7:33 PM
gporter's Avatar
gporter gporter is offline
Wow. Good job paul
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 3/7/06, 11:44 PM
Patrick Bolliger's Avatar
Talking Re: What Is Bonding......
I thought "Bonding" referred to the "moment" that you and your girlfriend agree that you both share a special place in each others heart...
OH Dang.. The other bonding!!
I-lectrical continuity physically connection to "attach" metal parts to each other to minimize resistance in electrical systems and permit current to travel back to the main panel safely without requiring a different path other then the electrical system... Like YOU and ME...
Old 3/8/06, 8:55 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Thanks Paul - it's refreshing to recieve great info from someone who understands what we do.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 3/8/06, 9:00 AM
Hey Bill.......thats what I am here for fella.....If you ever need anything just ask my friend.
Paul W. Abernathy
Old 3/8/06, 9:30 AM
William J. Decker's Avatar
Paul;
May I note that all of your example posts (excellent, BTW) show metal conduit. Didn't you say that ROMEX was OK and having the wiring enclosed in EMT was just plain silly?
Come on over to the 'Dark' side, Paul. Join us with the Chicago Codes!
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/8/06, 9:51 AM
Will,
lol......not my images..gotta work with what I got fella...lol.....
Yes, Chicago has some strange and expansive AHJ rulings for sure...
Oh.......lol...I never said silly..lol...just not for me fella...lol...I dont like pulling wires in conduit and most certainly not in homes...in fact I dont like working with AC either in homes...lol.....ME LIKE NM Cable...
Paul W. Abernathy
Old 3/8/06, 10:17 AM
A Dan Leleika A Dan Leleika is offline
Ditto!!!
I find the types of posts and info that Paul provides very usefull and informative.
Thanks Paul!
Old 3/8/06, 12:40 PM
Russel Ray's Avatar
Paul lol's too much. He obviously has waaaaaaaay too much fun doing what he does. Me? I have to resort to Mr. Cuervo and Mr. Vicodin.
Old 3/8/06, 4:39 PM
" Fault current returns to the power supply (source), not the earth! "
Jeez, this stuff just drives me crazy. Does this mean fault current returns to the pole on the neutral conductor via the grounding or neutral bus bars (depending on the location of the fault)? Doesn't the neutral conductor then go to a driven rod at the base of the pole?
If fault current goes through the ground bus bar, why doesn't it wind up going to the ground via the service grounding electrode? -Kent
Old 3/8/06, 4:52 PM
mmorgan mmorgan is offline
Exclamation Re: What Is Bonding......
I ran across this site that explains the difference between grounding and bonding. It helped clear it up for me.
http://www.home-inspect.com/itatips/02-06.asp
Old 3/8/06, 5:42 PM
Kenton,
The current must be balanced. "What goes in must come out." So what ever amount of current is going through the loads via the hot wires from the pole must return to the source (the pole) through the neutral, because this is the path of least resistance.
The ground wires provide a low resistance path back to the neutral bus and then to the pole or transformer. On a fault, this low resistance path will allow a large enough current (current = voltage divided by resistance) to flow through the hot conductor to trip the breaker. But once it has reached the neutral bus, it still goes back to the transformer.
As the link in my previous post explains - the grounding system keeps a person in a parallel path with the grounding system. On parallel circuits, most of the current will travel through the least resistant conductor, thus very little current will flow through the person who happens to come into conduct with something that is grounded but is still live.
Old 3/8/06, 5:45 PM
Russel Ray's Avatar
So if all the electricity that comes to me eventually goes back to the electric company, why do I continue to get an electric bill each month? I'm confused. If I pay for it, I wanna keep it. Seems to me that we should be putting up a brick wall on the return highway, keep what we've paid for, and recycle it. What am I missing?
Bonding Piping 101....Good To Know ! pabernathy Electrical Inspections 37 4/28/07 11:25 AM
Nat Gas water heater electr. bonding lfreeze Electrical Inspections 14 1/15/07 10:16 PM
Bonding dmacy Electrical Inspections 20 12/29/06 10:43 AM
Demystify Grounding & Bonding Class pabernathy Inspection Education & Training 5 12/24/06 1:10 AM
