Old 1/13/12, 8:55 PM
Sean Fogarty's Avatar
Default Bonding of plumbing
I generally call out lack of a visible bond of the plumbing supply to the main panel no matter what age the home is. I often find many older homes lack this applications. Just curious what other document when delaing with this.
Thanks in advance.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/13/12, 9:25 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: Bonding of plumbing
Do you mean the metallic hot and cold water pipes? Are you using the NEC to require that the plumbing piping be bonded to the electrical system?
Old 1/13/12, 11:00 PM
Yes hot and cold supply.
Not necessarily the NEC but general rules of practice for most homes in the area here. and yes as required by the NEC as well.
865-256-5397
Old 1/13/12, 11:12 PM
Jeffrey R. Pope's Avatar
I always attempt to verify the bond if the interior piping is metallic, regardless of the age of the home.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/13/12, 11:18 PM
Do you recommend it is found or corrected if you cannot verify?
865-256-5397
Old 1/13/12, 11:29 PM
Yep. I recommend that it is verified or established by a qualified electrician.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/13/12, 11:47 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
We are required to verify bonding of appliances as part of our state's SOP. A fellow inspector created an appliance bonding tester for it. Can the bonding for the plumbing be established in the same way using this tester which establishes continuity?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 1/13/12, 11:57 PM
Michael R. Boyett's Avatar
Richard, that tester (which I'm familiar with ) really just tells us that the appliance chassis (or whatever is being tested) is connected to the EGC. It doesn't tell you how, in other words, to know for sure how the bonding is accomplished you would have to visually observe the wire and it connection. So, no...do not use the tester to confirm water lines are properly bonded.
Old 1/14/12, 8:38 AM
Joseph M. Whitt Joseph M. Whitt is offline
The NEC does not require a bond from cold to hot. It only requires that the potable water be bonded in an assessable location and then only if it is a complete metal water system. Should repairs be done and nonmetallic parts used then the equipment grounding conductor that supplies the circuit that is likely to energize is all that is required.
Mike Whitt
Contractor/Instructor
Old 1/14/12, 3:54 PM
Bonding connection confirmed....
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/14/12, 4:31 PM
Jeff, why would they install that bonding ground at the exterior like that in lieu of the interior so aesthetically, that spigot would look a little better.?
Old 1/14/12, 6:17 PM
James F. McKee's Avatar
it's California Marcel...they are a little different over there.......just sayin...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 1/14/12, 6:22 PM
Different is right Jim.
Old 1/14/12, 7:17 PM
Jeffrey Moore Jeffrey Moore is offline
Done the same way here in AZ too Marcel, but our brains are baked in the summer.
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 1/14/12, 7:33 PM
Hi Jeff, hope all is good down in Arizona. I am sure it is better than the 8 degrees up here right now.
Yup, up here the bonding is made at the water meter in the basement.
Then of course we got the frostless spicots on the outside instead of those old boiler drains or toggle bibbs.
Neutral bus bar failed inspection Greg Moritz Electrical Inspections 18 1/19/08 1:53 PM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
